05-13-2020, 03:47 PM | #1 |
Drives: Camaro Z/28 - 2015 Join Date: Sep 2019
Which offset for the rear axle at 11x19?
Hello friends,
I am considering to order magnesium wheels from Litespeed Racing for my Z28. The problem is that Litespeed can only produce magnesium wheels up to a width of 19x11. So I thought I would go from 11.5x19 to 11x19 in the back. Does anyone know which offset to choose to make it fit in the rear? The offset from the 11.5x19 is +32, as you know all. Thanks! |
05-14-2020, 12:00 PM | #2 |
Drives: 2015 Z/28 #0058 Join Date: Apr 2018
Offset and tire width are what matters... If you're using the same 305 width... Use the same offset
Offset is measured off a wheel's center, not an outer edge. So rim width is irrelevant use this tool for visual https://rimsntires.com/specspro.jsp And if you're getting wheels made, get 4 with the same specs and use spacers in the front for the offset variance. So (4) 19x11 +31 wheels and then run a 20mm spacer upfront to get it to the +11 spec. Then you can rotate the wheels and tires
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ Last edited by j o n; 05-14-2020 at 12:34 PM. |
05-14-2020, 12:54 PM | #3 | |
Okay, thanks for the infos. |
05-18-2020, 08:21 AM | #4 | |
Drives: . Join Date: Jun 2016
I have (4x) 19x11 +25 wheels and running a 15mm rear spacer and a 20mm front spacer. But also note you will need to fit extended wheel studs to the hubs in order to be able to run 15/20mm spacers. |
05-18-2020, 02:32 PM | #5 |
Drives: Black 2015 Z28 #457 Join Date: Sep 2016
Is there a reason the front 19x11s woudn't work in the rear? Is there a physical clearance issue I'm missing?
05-18-2020, 10:12 PM | #6 |
Drives: 2015 Z28 #158(Black)& #955 (White) Join Date: Jul 2018
Forgestar wheels
I had a set made...
19x11 offset 32 - 120x5 |
05-19-2020, 09:46 AM | #7 | |
OE front on the rear will have about 10mm more poke out of the arches which isn't much. Looks quite good like that. |
05-19-2020, 09:55 AM | #8 |
Awesome! Thanks Pat.
05-19-2020, 10:20 AM | #9 | |
People have run 26 offset wheels, on the rears, with 305s on the track, no problem
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
05-20-2020, 06:23 AM | #10 | |
This is because the front is an 11J wide rim rather than 11.5J. As I said, it's more like 10mm further out, and it works fine, even with 325s There is loads of room in the wheel arches on these cars. |
05-20-2020, 06:31 AM | #11 | |
offset is measured off the wheel's center line, which is constant, changing the wheel's width has no impact on measuring offset For visual: https://rimsntires.com/specspro.jsp
Current:
05-20-2020, 12:42 PM | #12 | |
I thought it was 10mm but it's actually 14.7mm to be exact: |
05-20-2020, 12:48 PM | #13 | |
Current:
05-20-2020, 01:00 PM | #14 | |
For ref the first one I used was www.willtheyfit.com |
