03-17-2023, 09:02 PM | #1 |
Drives: 2010 Camaro SS A6 Join Date: Oct 2018
LSD options
Hello. What is everyone using for their LSD in regards to the Drag Strip. I see that Eaton only made the TRU-TRAC through 2015 for the Camaro. I thought I saw a helical gear LSD from Yukon and then another from another company that I've never heard of.
Thanks |
03-18-2023, 03:26 PM | #2 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Yup, they hold up to a lot of HP, big HP. You'll probably break an axle or driveshaft before the diff.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
03-18-2023, 04:21 PM | #3 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Can confirm the DS breaks before the diff.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
03-18-2023, 08:19 PM | #4 |
Thanks for the reply. I see now the diff itself is strong. My concern was if the diff is like most std limited slip diffs that use clutch plates that eventually wear out especially if drag racing. I know the tru-trac which was a huge player on the 2010-2015 camaro ss, uses a helical gear type lsd and doesn't use clutch plates. Just curious about the current "type" of LSD in camaros and why Eaton doesn't make a tru-trac for the 6th gen camaro.
03-19-2023, 07:59 PM | #5 | |
03-19-2023, 09:30 PM | #6 | |
Drives: 2016 2SS Convertible Join Date: May 2012
https://www.camaro6.com/forums/showthread.php?t=547186 |
