04-17-2021, 12:12 AM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
inner tie rods
what are those washers for? I do not see any of those installed on the stock inner tie rods.
04-17-2021, 12:31 AM | #2 |
They look like a lock washer, they go behind the inner tie rod and you bend them into the flat section near the ball. This prevents the assembly unscrewing its self.
04-17-2021, 02:04 AM | #3 |
Banned
Drives: 2010 LS Join Date: Feb 2021
Yeah, they are a lock washer. I did mine, and they didn't come with those.
04-17-2021, 02:16 AM | #4 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
I did mine as well and didn't have those either.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
04-17-2021, 10:46 AM | #5 |
Drives: 2SS/RS Join Date: Sep 2008
As already stated they are lock washers and the tabs are bent once everything is screwed in and installed. Depending on the vehicle, and the manufacturers design of the tie rods, they may or may not come with them (usually the cheaper aftermarket ones do while quality ones don't).
04-17-2021, 08:31 PM | #6 |
so I shouldn't worry about them if there is none on the stock ones.
04-17-2021, 10:37 PM | #7 |
If the ones you bought came with them, I would use them if I was doing it. The stock ones not having them could just mean they was manufactured differently and designed to not need them where as the aftermarket ones do.
04-17-2021, 10:38 PM | #8 |
I'm not sure you shouldn't use them. But I did use some lock tite on mine.
04-17-2021, 11:06 PM | #9 | |
Banned
I've never used thread-locker on them, and I have never had one come loose. I have had well over 15 cars, and I took them off, and put new ones on. None of them had lock washers, and I didn't use a thread locker. I did my inners and outers last summer, no thread locker or lock washers. They're still on.. |
