07-31-2021, 03:38 PM | #1 |
Motor build for boost
So I just threw a rod through my oil pan and bent two lifters at the track not long ago. So now I'm looking at doing a full build for high boost. I'm just wondering if the block is OK, which it seems it is. If I should build the aluminum block or go with an iron block. A 6.0 or similar.
UPP 58mm TT, 127lb per hr. Injectors, e85 flex fuel w/ duel Areomotive fuel pumps, TSP stage 3 blower cam 900+hp 9.5psi
07-31-2021, 03:46 PM | #2 |
Drives: G8 Join Date: Mar 2012
What are you goals?
Sent from my Pixel 4 XL using Tapatalk |
07-31-2021, 04:02 PM | #3 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Iron 6.0 block and a set of rods/pistons will be enough. 365-370 cubes and send it
08-01-2021, 05:21 AM | #4 |
Drives: it changes Join Date: Nov 2010
I'd say you'd be incredibly lucky for the block to be ok after throwing a rod.
If you don't mind the weight, just go iron, although a well built LSA or LS3 based block would be fine depending on what's available these days |
08-01-2021, 08:43 AM | #5 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Damn you where at over 900 hp on stock bottom end?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
08-01-2021, 08:45 AM | #6 |
Drives: 2011 Camaro SS Join Date: Jul 2017
Just curious what compression you are going with.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
08-04-2021, 05:43 PM | #7 |
Looking for at least 1500whp
08-04-2021, 05:47 PM | #8 |
It was at 900 on the dyno but was dialed back to 830 over concerns of the transmission and rear end. It was only at 700 on the pull that killed it.
08-04-2021, 05:49 PM | #9 |
You need an aftermarket block and good parts an off the shelf twin kit isn't gonna do it. Budget about 25-30k for a reliable longblock alone
08-05-2021, 10:25 PM | #10 |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
Have you peeked at this thread created over the years... It’s a sticky in the Forced induction V-8 area...
https://www.camaro5.com/forums/showthread.php?t=311407
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
08-06-2021, 05:35 AM | #11 | |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
I dont think stock sleeves would last long at that level.
https://www.thompsonmotorsports.net/...product_id=558 I got my 1300hp dart long block package from them for about $10-$11k. They have guys making 1700whp on this "1300hp" setup with turbos. It seems like it might be do-able for less than $25-30k, but then again, you have done it, and I haven't.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
08-06-2021, 09:30 AM | #12 | |
08-07-2021, 11:59 PM | #13 |
[QUOTE=eLeSthree;11051008]I dont think stock sleeves would last long at that level.
I didn't plan on having anything stock on the motor. I just wasn't sure how long an aluminum block, even sleeved would would last at that power.
