01-07-2018, 07:17 AM | #1 |
Drives: 2010 Chevrolet Camaro 2LT Join Date: Mar 2017
Help!! Gas fuel dumping out of my exhaust pipes..
Hi friends!! I have a problem with My 2010 Chevrolet Camaro 2LT V6..
Today, while driving it suddenly lost power with the message display “reduced engine power”... Secondly, the camaro started jerking with a huge horrible smoke coming out of the exhaust pipes.. I also have raw gas fuel dumping out of the exhaust pipes... I keep wondering if I have a stuck injector or something else.. I tried diagnosing the camaro with my OBD scanner and the error codes are: P0089 (fuel pressure regulator 1) P0097 (fuel rail /system pressure- too low) Please help me with ideas.. I’m losing this car.. God bless you all.. |
01-07-2018, 07:52 AM | #2 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Get a new fuel pressure regulator, clear codes and change the oil.
See how it acts after that.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
01-10-2020, 10:55 AM | #3 | |
Drives: Camaro V6 2011 and 2014 V6 Join Date: May 2017
Hello John. How I can change the fuel pressure regulator?? I have the same issue and I not found the fuel regulator in any place. My car sudently has 3 misfires (cyl 1,3 and 5) and a strong smell of gas, got codes P0089, P0301, P0303 and P0305 I think this car have the fuel pressure regulator in the high pump fuel, and this pump its very expensive |
01-10-2020, 11:19 AM | #4 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
On my LFX I had the high-pressure pump fail and dump fuel into my engine.
Attached is the invoice from that, that might give you an idea and such.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
01-10-2020, 04:16 PM | #5 | |
Banned
Drives: cheby Camaro Join Date: Aug 2019
