Old 08-23-2021, 03:45 PM   #1
kbear951
Drives: 2013 Camaro 2SS, L99
Lifter Tick Options
Hey guys…I have a 2013 Camaro 2SS L99 with 123,000 miles that has a pretty bad lifter tick. It has been on going for a while, but nobody else “could hear it.” ��
The day before my warranty expired, it got louder, still the liars at Chevrolet said “that’s what it’s supposed to sound like.” I’m not stupid, I know they heard it. Anyway, here we are 1 month later and it’s gotten progressively worse and now I’m really worried!! Apart from going in there and replacing them, is there anything I could do that is less invasive? I was going to do my oil change again soon. I only put desos Mobil1 5w30 in it. One time I tried the desos Mobil1 5w30 high mileage oil and it got louder (this is back when I was the only soul on earth who could hear it), so I took it back out and put the regular Mobil1 5w30 and changed the filter again. I believe for filters I’ve been doing the AC Delco filters, but can’t remember for sure. If I did something else is was probably Mobil1 or KnN. Should I try a heavier oil? If so, which one? Is that for sure safe? Have you tried it repeatedly over a long period of time? I really don’t want to sell her, I just want to take good care of my car and keep it, but have been mulling the idea around because of this. A few weeks ago I noticed my oil pressure at idle was a bit low intermittently (around 20-ish), but haven’t been paying attention since bc it stresses me out lol. Any suggestions? What is the consensus on additives? Are there any that are for sure safe? HELP!! ��I love her….��
kbear951 is offline   Reply With Quote
Old 08-23-2021, 03:56 PM   #2
gtstorey
No oil change or additive will fix a mechanical problem. Find a non-dealer shop you can trust and let them do a proper diagnosis.
Old 08-23-2021, 06:04 PM   #3
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
It's the DOD lifters, they are a known bad spot. The best thing is to replace them and do a DOD delete
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 08-24-2021, 01:59 AM   #4
Ponchonutty
Ponchonutty's Avatar
Drives: 2012 SS L99 Converible
What others have said. It’s just a matter of time when they let loose and send shrapnel through your your engine at which time you’ll need a new one. I just had this issue with my 12 with half the miles. I change my oil religiously at 5k no matter what but it still happened. My GM Denali all I did was tuned out the DOD and it had no issues all the way past 280k miles
2012 L99 Convertible SS
Tooley Racing Stage 2 DOD delete, 3,200 stall converter, Shorty headers and custom stainless exhaust, CAI, and tune as mods
Ponchonutty is offline   Reply With Quote
Old 08-26-2021, 07:48 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
There is an improved design of the Active Fuel Management lifters, and a TSB to go with them.
I had this work done under warranty, around 30,000 miles. All is good at 80,000 now. With your high mileage, you're probably gonna need the lifters AND the camshaft replaced. But you don't have to delete AFM necessarily. If yo do, though, the conversion will require a numvber of parts and a tune.
Rock-It Man is offline   Reply With Quote
Old 08-27-2021, 12:07 AM   #6
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
If your going to keep it then I would recommend a afm delete, small cam upgrade, and a tune. The afm system is really crap. You will be way more reliable without the afm and it doesn't really affect gas mileage, maybe like 1 mpg at most only when cruising on the highway. I did the afm delete and cam upgrade on mine at 153k miles so it's definitely worth the investment if consider how much a new vehicle will cost. And you should be good well past 200k miles.
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 08-27-2021, 12:21 AM   #7
Ponchonutty
I started having cold start lifter noise but would quiet down shortly after startup last summer. Then it melted a solo performance cat. I wasn’t sure if it was from the last tune or what and I didn’t want to take that chance. I was running with the DOD tuned off for about 25k miles with no issues before this. Anyways, I ended up replacing all of it and put a small cam in it too since I was already in there. Wish I would have done that years ago.
Old 08-27-2021, 02:50 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^^ This right here, spot on 100% great advice!! I did mine at 98k..
Old 09-08-2021, 03:00 PM   #9
kbear951
I suppose if now my cruising 70 mph oil pressure is 40-45, shooting up to 50-55 when I punch it and it feels like there is resistance and it gets a little shakey when punching it (which I won’t be doing again), that would mean I now have metal in my oil clogging something up a bit, right? Feeling like this is a ticking time bomb I think I’m going to get a little ding on the body patched up and try to ditch it ASAP and start driving my truck in the meantime.
Old 09-08-2021, 05:18 PM   #10
morepowerjoe
Well I don't think that you have metal in it yet because it still runs correct? And it doesn't have a rod knock right?It's more then likely just fixing to let loose. But if you do something about soon then it will be very reliable once again. So I like I said before, you need to get it fixed one way or another cause it will be cheaper to fix it then to get a new car. Unless you have your eye on something less than the amount it will cost to fix it which I think can be done for around $3500 give or take including labor. Now if you find a tuner to do it for you, you could possibly save about $800 because I'm including the tune which a tuner will have access to tune it himself. I wish I would have thought of this when I did mine.
