09-13-2020, 11:50 AM | #1 |
Drives: 2011 SS Join Date: May 2020
Tach signal
I'm wondering if anyone knows a connection point to find the tach signal? I'm hooking up an innovate wideband/boost gauge with shift light. Purple wire goes to tach signal.
Did gm put in a connector for this? Or just use coil negative side? |
09-14-2020, 07:44 PM | #2 |
Drives: 2014 SS 2010 SS 93 Camaro z28 Join Date: Apr 2017
There’s a few post about it on here or you can get the msd tach adapter
09-14-2020, 10:03 PM | #3 |
Thanks for the info, I can work with that.
09-17-2020, 01:51 PM | #4 |
Drives: 2010 Chevy Camaro ss Join Date: Oct 2017
Get the AUTO METER 9123 RPM Signal Adapter for LS Engines. Its plug and play and clean . I use one never had issues. Less than 5 min install.
09-17-2020, 03:57 PM | #5 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I just tapped into the #1 coil plug. Worked for NOS controller and AEM Failsafe gauge.
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
09-18-2020, 09:11 PM | #6 |
What color wire cracka? Pink wire won't work for me
09-21-2020, 02:01 PM | #7 |
I'll go take a pic.
09-21-2020, 02:54 PM | #8 |
looks like the purple one next to the pink one.
09-21-2020, 08:09 PM | #9 |
Thanks, I'll try that
09-27-2020, 08:08 AM | #10 |
Purple wire worked, set setttings to 1/.5.
Thanks |
Thread Tools | |
