08-22-2017, 07:04 PM | #1 |
Drives: 2013 Camaro Join Date: Feb 2016
Flowmaster 8425154 or magnaflow 11386
Which of the two do you guys recommend? I have a muffler delete and want to go with one of the two.
Thanks Sent from my iPhone using Tapatalk |
08-22-2017, 07:21 PM | #2 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
First, not sure if you have a V8 or not, nor sure if that really makes a difference. I love Flowmaster... good set of catbacks on my ride that do not drone. Some they do drone however, so it seems to be a gamble here. I don't think Magnaflow drones as much for people as Flowmaster.
Now the Flowmaster muffler you're calling out: ... has got two inlets and two outlets. Unless you're planning on installing a centered set of exhaust tips (similar to the C7 vettes), or planning on bending the pipes inward then outward again...I'm not so sure that is compatible with either a V6 or a V8 Camaro. Same with the Magnaflows... |
08-22-2017, 07:22 PM | #3 |
Drives: 2012 IBM 2SS/RS LS3/M6 Join Date: Apr 2015
I had a resonator delete with Flowmaster Super 10's and loved it. Mild at idol and a nice loud deep tone when getting on it.
I recently added LT headers with high flow cats and I love it even more. A lot louder, but sounds good. A little raspier, but not too bad.
Stainless Power LT Headers, K&N Typhoon CAI, VMAX Ported Throttle Body, Jannetty Tune, Phastek Scoop & Washer Bottle Relocator, VTC
Resonator Delete w/Flowmaster Super 10's, BMR Lowering Springs, Koni Orange Struts, Factory Hurst Short Throw Shifter, Skip Shift Eliminator, DRL & Halo Harness, Window Valet Scosche Kit w/Pioneer AVH-4100NEX, Lloyds Custom Mats, Blue LED Footwell Lighting |
08-22-2017, 07:24 PM | #4 |
Mine is a v6 and I had the 11386 but the muffler guy told me that the flowmaster will give me a better deep sound plus I don't know which of the two will give me the less drone inside as well.
08-22-2017, 07:33 PM | #5 |
Not sure if those are the right part numbers... never seen a muffler on a Camaro with dual inlets/outlets... you want something like the Flowmaster 817483's, imo. These are 2.5" inlet though... not sure if you have 3" catback pipes.
eta; Amazon's got 4 out of 5 stars for this 817483... https://www.amazon.com/Flowmaster-81.../dp/B0035J83EI |
08-22-2017, 07:51 PM | #6 |
My mistake, I guess the set up really is different on the V6...
Still, consider the set on Amazon... looks like a great choice. |
08-22-2017, 08:08 PM | #7 |
Drives: 2014 Camaro 2SS/RS 1LE Join Date: Nov 2016
If you don't want to hear a drone, I would go with the Magnaflow. I have had both mufflers in the past and the Flowmaster was terrible at cruising speeds. I feel the Magnaflow gives you more of a deeper muscle car sound.
Mods: K&N CAI, AR long tube headers, high flow cats, NPP exhaust
08-22-2017, 08:15 PM | #8 |
08-22-2017, 08:17 PM | #9 | |
Glad you had both so you know the sound. I really like the magnaflow 11386 sound but I was open to hear the flowmaster 8425154 sound as well and compare . I don't want a lot of drone plus I read somewhere here about j pipes? Sent from my iPhone using Tapatalk |
08-22-2017, 08:20 PM | #10 | |
Ret AF, cancer survivor
Drives: 2013 Camaro 2SS/RS & 2006 Corvette Join Date: Jul 2015
OP: As you can see, it all comes down to personal taste. As I've said before on this issue, I would look up my local Camaro club and listen to both, as well as others, to get a good idea of what they would sound like on your vehicle. Keep in mind how they sound on one car may differ from what they will sound like on your vehicle depending on what's been done to the other car versus what you have/have not done to yours.
08-22-2017, 08:28 PM | #11 | |
The muffler shop owner said that he would put both on so I can hear the sound of both and see which one I like more. Sent from my iPhone using Tapatalk |
08-22-2017, 08:30 PM | #12 |
Sounds like a great shop & this way you won't have any regrets or second thoughts
08-22-2017, 08:32 PM | #13 | |
Yeah that's what he told me but do these open up like after 200 miles or so on them? Will I be able to hear the real sound just right there on the spot ? Thanks by the way for all your advices fellas Sent from my iPhone using Tapatalk |
08-22-2017, 09:02 PM | #14 |
Most mufflers tone will change a little bit as time goes on. But it should be really close.
