01-09-2017, 11:51 AM | #1 |
Drives: 2015 camaro 2lt Join Date: Dec 2016
how long should the stock perlli p zero neros last
it seems that my p zero neros are wearing kinda fast the rear even more, how long did yours last ive done a couple small burn outs but thats all and right now i spin like crazy in the ice and snow.
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5 Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85. |
01-09-2017, 11:52 AM | #2 |
i have 5k miles on them.
01-09-2017, 11:53 AM | #3 |
Tri-County Camaro SWFL
Well PZeros are a summer tire. So I would highly expect them to spin in snow, ice, rain and colder temps. Also burnouts kill tires
01-09-2017, 11:55 AM | #4 |
they are the all season verson that comes on the 2lt
01-09-2017, 12:17 PM | #5 |
Drives: 2011 SGM 1SS/RS M6 Join Date: Feb 2012
Per the manufacturer, they are warrantied for 45k miles if rotated / cared for properly. They will cover half this amount if the front tires are a different size than the rear.
I would suggest limiting burnouts and hard launches unless you enjoy spending money on tires. Burnouts will eat tires EXTREMELY quickly. Get a tread depth measuring tool - only a couple dollars at an auto parts store. Look at how much tread the tires came with new (per manufacturer website or easy to find on Tire Rack), and how much you have left - will give you an approximate rate at how fast you are eating through your tires. I am assuming tires wear at an even pace, but say brand new they had 12/32. Failing your state inspection is 2/32 (or at whatever point you plan on replacing them), so 10/32 of usable life. If at 5,000 miles you have 9/32 remaining, you have used 3/32. 3 over the 10/32 available means you have used 30% of the life of your tire. Take your 5000 miles on the tires, divide by 30%, (5000/0.30) and you'll get approximately 16,666 miles out of the tire. All these numbers are arbitrary - measure your own tires and see what they came with new to come up with an approximation. On the Pzero summer tire for SS models, I am going to get approximately 22,000 miles out of mine, you should be able to do significantly better than that with the same size at all four corners, especially with a longer life tire.
Current: 2011 SGM Camaro 1SS/RS M6 - CAI Cold Air Kit, Janetty Tuned
01-09-2017, 12:41 PM | #6 |
Drives: 13 Camaro Join Date: Oct 2016
About ten minutes
01-09-2017, 01:23 PM | #7 |
Drives: 2012 2SSRS Join Date: Jul 2013
I got 20k off mine and that was pushing it to its limits
Money may not buy happiness, but I'd rather cry in a Chevy than in a Ford!
01-09-2017, 01:33 PM | #8 |
Drives: 2011 L99 SS Join Date: Oct 2014
Deleted.
Last edited by nosmr2; 01-10-2017 at 07:17 PM. Reason: Comparing apples to oranges is frowned upon. My bad. |
01-09-2017, 01:54 PM | #9 |
Drives: LT W/2LT,blue metallic Join Date: Jul 2016
got 15,000 on mine and the front and back look pretty good still.but im not doing smoke shows to impress my girlfriend,and she wont be impressed when you cant afford to go out because you bought new tires.
01-09-2017, 02:19 PM | #10 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
P/Zeros in the winter! Keep your insurance paid up.
01-09-2017, 03:27 PM | #11 |
Drives: '13 1SS/RS IOM white stripes Join Date: Oct 2013
I have almost 30k miles on mine ,though I will need a new set by spring.
01-09-2017, 03:59 PM | #12 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
You'll get about twenty thousand miles on the rears , a little more on the front. I squeezed 27000 out of my rears but they are slick.
01-09-2017, 04:15 PM | #13 |
376 cubic inches of fun
There's no right answer to this question because it depends on how you drive.
I used the P-Zeros mostly for touring and got 50,000 miles out of the fronts. The rears were probably good for another 10K, but I replaces all four together with all season tires. |
01-09-2017, 07:27 PM | #14 |
Drives: '23 LT1 A10 Join Date: Oct 2015
Almost 18k miles on my car and the rears are getting close for replacement. Fronts are like new.
24 LT1 M6 Sharkskin Metallic
