08-09-2016, 08:35 PM | #57 |
Drives: 2013 Camaro ZL1, M6 Join Date: Sep 2015
Ted,
So all these mods can be run safely without upgrading the heat exchanger. I'm looking for something very similar and just trying to budget for everything I need to support the setup. Thanks.
93 tuned, 736 rwhp, 691 rwtq. FBO HCI, 2.5/9.5 pulleys, PCM’s of NC ‘ZL Win’ Cam, stock crank, Wiseco pistons, Callie’s rods, King main/Rod bearings, 1050x injectors, Elite E2 catch can, Rotofab CAI, Johnson 2110 lifters, AI 280cc p+p heads, ported 90mm TB, Lingenfelter HX, D3 reservoir, MSD BAP, BTR valve train, head/main studs, Melling oil pump, Straib trunnions, C5r timing chain, Kooks 1 7/8 LT’s w/ cat delete.
08-09-2016, 09:45 PM | #58 |
Drives: Fast Join Date: Mar 2015
I think you'd be better off emailing him directly. It's: tedj@jannettyracing.com.
08-09-2016, 10:26 PM | #59 |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
Ted has my car as we speak with this cam going in
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
08-10-2016, 06:44 AM | #60 | |
We pride ourselves on a balanced performance package the produces more power on lower boost. Boost is a product of restriction, and restriction produces heat. Our package relieves that restriction to unleash more power. Feel free to give me a call to discuss. Ted.
www.jannettyracing.com
10-09-2016, 02:26 PM | #61 |
So you don't necessarily need to upgrade the heat exchanger or add a reservoir tank because the boost levels are conservative?
10-09-2016, 02:28 PM | #62 |
Oops. Ignore last post.
10-09-2016, 07:04 PM | #63 |
Drives: '21 ZLE A10 Join Date: May 2012
if you run at a road course, you would be wise to add a reservoir and a larger heat exchanger...my opinion. For drag racing, the factory unit will suffice.
10-10-2016, 08:25 AM | #64 | |
I have yet to see any benefit of a larger heat exchanger and or reservoir under the hood. Larger heat exchangers Upset the balanced air flow across the engineered cooling pack, so a bit of rob Peter to pay Paul. So you end up with more Weight, and Hotter running Radiator, AC condenser, engine oil, trans oil, and diff oil. The cooling limitation is the Brick inside the supercharger NOT the super efficient Heat exchanger out front. Secondly it is hot under the hood, so the Idea of placing an aluminum reservoir in the hot engine compartment is absurd, it goes against any common sense. Hot always goes to cold, simple physics, Hot under hood temps are absorbed through the reservoir in to the cooler liquid further heating it before it goes out to the cooler. The Very reason why GM did not include one in the first place, less water in the hot engine compartment the better. Like I said earlier, The Best Gains are from removing restriction, reducing friction, balancing air flow in and out of the engine. We make more power on Less boost with our power packages and carry the power to the finish line. Ted.
10-10-2016, 08:42 AM | #65 |
Drives: ZL1 Convertible Auto Join Date: Apr 2015
When I was at the drag strip (not a road course, I know) there were only 40 cars there total so I was running back to back runs as fast as I could get down the return road. I did 15 runs total. I never lost anything. As long as I hooked I was good for a high 10 at 128-130 mph.
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
10-10-2016, 08:50 AM | #66 | |
The recovery of the factory system is amazing, it fully recovers on the return road. I road race my car regularly and never lose any power, IAT are always in check.
10-10-2016, 10:20 AM | #67 |
The one that is cut off was a 10.973
4 runs in 14 minutes. My 60 ft dropped a tenth on the 10.9 vs the 10.84
10-10-2016, 10:40 AM | #68 |
Freakin Awesome !!!
05-30-2018, 08:48 AM | #69 |
Great discussion
