05-27-2016, 02:53 PM | #29 | |
ALL the boost
Drives: 2019 Camaro 2SS A10 Join Date: Nov 2014
2019 Camaro 2SS A10 // ECS Novi Centri // Speed engineering 2" primary longtubes // 3" straight pipe collectors back // LT4 fuel system // Airlift performance 3P/3H
2010 Camaro 2SS 6MT // Cat delete // Muffler delete // resonator delete // Turbonetics kit // BC Coilovers // BMR Trailing arms // BMR toe rods // BMR bushings whole rear // LPW diff cover // FIC 1000cc injectors // ZL1 Fuel pump--646whp / 670wtq @ 8psi--Sold |
05-27-2016, 03:00 PM | #30 | |
no micro switch sounds perfect to me... |
05-31-2016, 10:19 PM | #31 | |
Too much is never enough!
Sorry for the delayed response.
There are two ways this works, you set your RPM limit at say 1500, or whatever you want to leave the line with, once you press in your clutch, and have reached that set percentage point, that will trigger the CTAP, your not gong to exceed that set RPM. Now once you are driving down the road, or strip, and you shift at say 6k, it will limit you from hitting say 6500 RPMs because you have again, triggered the CTAP to arm your two step. Thats why it works so well for NLS. Hope this helps.
06-07-2016, 08:02 PM | #32 |
Drives: 2010 IOM SS Join Date: Nov 2014
What kind of wheel spacers where you running? Amazing build btw
06-30-2016, 09:31 AM | #33 |
ALL the boost
No wheel spacers now, just proper offset ZL1 reps.
06-30-2016, 09:37 AM | #34 | |
ALL the boost
07-31-2016, 11:49 AM | #35 |
ALL the boost
Been a little while since I had any updates. Took the car to the 1/8th mile track for shits and giggles this last weekend. Car ran consistent 7.8-7.9. The NT555R just aren't sticky enough for the power I'm making. Running the LNC-2000 at 2500rpms and retarding 6-7 degree of timing to build boost at launch, best I could get was a 1.90 60ft. I tried a bunch of different ways to warm the tires, ran them at 20psi, then eventually 16psi. That was when I started cutting 1.9s. Car was trapping 99-101mph all night. Just couldn't get off the line. Video and slip soon.
07-31-2016, 10:50 PM | #36 | |
2010 Camaro 2SS/RS Turbo build UPDATE: 5/23/16 TUNE RESULTS INSIDE!
Get some real drag radials, you will be much happier. Try launching at a higher rpm, I was launching around 3500 it wasn't high enough, but I was babying the rear end, I had it sold at the time. Also 15 psi is what I run in my tires at the track. Also play with your LNC-2000 it takes some time to get it, I still haven't got mine dialed in. Sent from my iPhone using Tapatalk
04-27-2017, 03:32 AM | #37 |
ALL the boost
Been a while. Car has had some serious visual updates since last post.
Phantom grill is gone. LED DRL, with the harness to make them work with headlights Black tail light bezels. Next will be the chrome exhaust rings. GMPP short shifter. Finally, I removed the silver factory stripes, painted ZL1 reps gold. (Picture taken before I removed old grill) Some things left to be done: New radio dash kit (will be here tomorrow, April 27) LED interior lights (will be here 27 April) Blackout side markers Not pictured: new LNC003 installed. Seems to build boost better/faster than my 2000 unit. I like it so far.
05-30-2017, 12:10 PM | #38 |
ALL the boost
Out of left field, I decided I wanted to do Air ride in my car. I didn't want to spend $3500, so I pieced together my own kit. I'm about $2400 in it, and i have everything i need. Here's a test vid with one strut.
https://youtu.be/1U_v7BjDhaA
06-08-2017, 07:55 PM | #39 | |
ALL the boost
Short vid, car is on air ride now thanks to Airlift.
2010 Camaro 2SS 6MT // Cat delete // Muffler delete // resonator delete // Turbonetics kit // BC Coilovers // BMR Trailing arms // BMR toe rods // BMR bushings whole rear // LPW diff cover // FIC 1000cc injectors // ZL1 Fuel pump--646whp / 670wtq @ 8psi--Sold Last edited by Da6d; 06-17-2017 at 04:43 PM. |
