10-18-2016, 11:55 PM | #1 |
Drives: Black 2013 Chevrolet Camaro LS Join Date: Sep 2016
Will Hankook Ventus ST RH06's Fit Camaro SS Rims?
Hi, All!
I recently purchased 20 inch 2015 SS wheels for my 2013 Camaro LS. The wheels came with Pirelli P Zeros but all 4 tires are pretty worn out. I purchased Hankook Ventus V12 Evo's for the front and Hankook Ventus ST RH06's for the back online that have the same measurements the as the previous tires. But, I am now a little worried as Tire Rack states Hankook Ventus ST RH06's are for "luxury SUVs and pickup trucks" http://www.tirerack.com/tires/tires....Ventus+ST+RH06 Will someone with a little bit wheel and tire knowledge then I confirm or deny that these tires will fit on my Camaro. Thank you all so much! -Erik |
10-19-2016, 07:44 AM | #2 |
Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
As long as the tires are the same size as the tires you are replacing, they should fit. Nothing wrong with that tire it's just more of an All Season Touring tire as opposed to a performance tire.
U.S. Army Retired |
10-19-2016, 09:17 PM | #3 |
Rolling along...
I ran those tires in 275/40R20 on all four corners (swapped the stock front 20x8's for another set of 20x9 rears so I could rotate all 4 tires) on my 2010 1LT/RS for 15k miles and then again on my 2011 SS for an additional 25k miles.
As long as you ordered 275/40R20, then they'll fit. I wasn't terribly impressed with them though. They were OK but definitely not P-Zeros. As the miles went by, the traction got worse and worse, especially on wet roads. Just be careful.
Thread Tools | |
