01-28-2017, 12:15 PM | #1 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
How hard is it to change the spark plugs on an LFX?
When I do my intake cleaning in the spring, I plan on doing an oil change & change the plugs afterwards. How difficult is it to get to the spark plugs? Do you have to get them from under the car, or is it easy to do it from the top?
Don M
Supercharged LGX + 6 speed manual = FUN!! |
01-28-2017, 03:10 PM | #2 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
Simple and straight forward. Remove/ unclip the harness from the coil pack, then there's a 10mm (i believe) bolt holding the ignition plug in place. After taking the bolt out, remove the coil pack and use a 5/8" spark plug socket to carefully remove the plug. All of the work is from the top and I would recommend OEM Acdelco. They are great quality and last a long time.
01-28-2017, 07:42 PM | #3 |
Camaro #4
Just making sure, each plug has it's own coil pack?
Don M
01-28-2017, 08:26 PM | #4 |
[COTW 4/13/15]
yes sir. Are you just wanting to change the plugs since you're doing the cleaning? I understand changing them is cheap maintenance but they are recommended to be changed at 100K if you weren't aware
01-28-2017, 08:47 PM | #5 |
Camaro #4
It depends, I'm going to pull the plugs to make it easier to turn the engine & close the valves. If they are bad, I'll change them. By the time the weather changes & I'm ready to do the cleaning, I'll have about 56K on the car. If the plugs are bad, I might try to clean them or I might replace them, I don't know yet.
Don M
01-28-2017, 09:25 PM | #6 | |
[COTW 4/13/15]
02-02-2017, 10:06 PM | #7 |
Drives: 2015 2LT RS Convertible Join Date: Dec 2016
if you are going to pull them, i would just replace them for the $42 in parts. That way you know the quality of the plugs you are putting back into the cylinder. Plugs are cheap. I just replaced the plugs in my 2011 Ecoboost F150 with 98K on them. They were missing enough to tell it when the cruise tried to keep up. they were $6.99 each for MC Iridiums.
02-12-2017, 11:04 AM | #8 |
Drives: 2012 Camaro 1LT RS Join Date: May 2012
I'm in the same boat, gonna be cleaning my IM soon and will be changing the spark plugs when I do. I found the AC Delco plugs on Amazon for $5.63 plus a $3 rebate per plug, so only about $16 for all six.
ACDelco 41-109 Professional Iridium Spark Plug (Pack of 1) https://www.amazon.com/dp/B001KSEGI8..._htjOyb3SCB5MM Sent from my SM-T800 using Tapatalk |
02-12-2017, 04:27 PM | #9 | |
02-12-2017, 06:14 PM | #10 |
Banned
Drives: Camaro Join Date: Mar 2013
Should be easy, it's only 6.
04-05-2018, 06:29 PM | #11 | |
