03-08-2018, 04:02 PM | #211 |
Drives: 2010 Camaro SS Join Date: Jan 2017
following this thread. Praying I don't have the same problem when I tune and dyno mine. Good luck man
F35 Cam / LOD X-1 Manifold / SLP CAI / LS7 Lifters / 3.91 Gears / Hooker Blackheart Exhaust / TSP Headers / SLP Underdrive Pulley / MGW STS / Trunnions and all that other fun stuff....
03-08-2018, 04:23 PM | #212 |
Drives: 2013 Camaro SS Join Date: Apr 2017
It's been awhile since I had to do a compression test, completly forgot about doing it at WOT. Mine was cold, turned over about 5 times and got that reading. I will do a WOT one tomorrow to see if it's different.
Also about your worry with the oil. Just drain some into a clean jug with a funnel so you can reuse it
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
03-10-2018, 10:36 PM | #213 |
Drives: 2010 Camaro 2SS/RS ABM 6M Join Date: Jul 2017
Small update. I was able to rule out that this was a dyno issue in any way. My tuner snapped a pic for me today. He had a 2013 M6 car come in with headers, cai, and a TSP stage 2 cam with stock heads
That car has me beat EVERYWHERE in the curve, and really pulls away once the revs come up. Peak was 484/487. I am the lower of both curves. Interesting this car peaks just before 5900rpm though. I would have guessed a bit higher. Also note that this car has torque swings in the exact same spots as mine. So that really might just be the way this mustang dyno loads the car up. Either way, it definitely appears my set up has a lot more potential than it's showing. Just gotta find my restriction.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
03-10-2018, 11:05 PM | #214 |
That is one happy dyno, that torque is quite high, hes got nearly 50lbs more Tq than my setup with a stage 3 cam. Which cam did he go with?
03-11-2018, 12:51 AM | #215 |
Drives: 13' 1LE Join Date: Apr 2012
That is one trashed up dyno and no hes not getting 490rwtq. Go somewhere else. 5900 peak..LOLL not even close. Should peak at 6400-6500 with stage 2, at least.
Heres the dyno sheet directly from TSP site their old and new stage 2.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
03-11-2018, 03:03 PM | #216 |
SS
where the torque swings.... sounds and looks like the dyno is nfg
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow catsLocks@7.5 degrees castor and radius arm inserts, Ride Tech 2coilovers JDP upper control arm bushings BMR lower knuckle bushing Bo White throttle body3.91 gears Spohn del-sphere toe link and trailing arms Prothane subframe bushings
03-11-2018, 03:13 PM | #217 |
Drives: 2015 1LE Join Date: Oct 2015
There is something wrong with that dyno. The accelerometer that takes measurements must be F'd up or something. How a tuner/dyno operator could look at those torque curves and think that is normal is beyond me, kinda sucks but atleast you know your shit is not abnormal.
03-14-2018, 02:25 PM | #218 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
any update, gadget?
Bone Stock |
03-14-2018, 03:25 PM | #219 |
Nothing major yet. I checked the rest of the cylinders and all of them are pretty much the same. Only deviates 1-2 PSI in either direction. So not helpful other than letting me know I don't have like a dead cylinder or anything..but wasn't expecting that or it wouldn't run well I imagine.
Have been gathering a few things. Getting ready to pull the timing cover and do a visual inspection first. I guess if the cam is not noticeably off, it'll be time to learn how to degree one. Hope to possibly start working on it tomorrow evening, actually. I will update if I find anything abnormal.
03-14-2018, 03:46 PM | #220 |
Also, even if there is a dyno issue causing weird numbers, aren't they mostly just a tuning tool anyhow? I trust the car is safe to drive, regardless of RWHP numbers.
That said, while he's been tuning for a long time, the dyno is somewhat recent. So, I haven't seen a whole lot of similar things coming off of it to compare to. And the next closest dyno that I know of is like 300 miles away. So not like I can pop over there real quick to see the numbers/curve elsewhere
03-14-2018, 04:29 PM | #221 | |
03-16-2018, 09:33 AM | #222 |
old school chevy rodder
Just to put it out there my great tuners dyno of my stage three TSP cam years ago show unsmoothed to show problem areas as should be.... with correct SAE correction factor and remote weather station on a mustang dyno tuned with HP tuning...just for comparison...
He tunes very well, no timing pulled etc and two electrical engineering degrees, the car was a 13 m-6 with dual mode CAI with scoop and SP headers and hfc..... so yes a happy dyno as a tuning tool...not so good.
03-16-2018, 01:14 PM | #223 | |
03-16-2018, 04:24 PM | #224 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
The Wall.
