Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 06-13-2018, 08:15 AM   #1
le'1le
Drives: Future 1LE
Fender (wheel well) liner carnage and advice
Just suffered my first casualty with the car as I ripped out the front right fender liner from hitting a cone wall at 60 mph or so.
The result is that i ripped the plastic rib from the inside of the front bumper where the liner mounts to. Has anyone else experienced this and could offer some advice on the best way to fix it? As a result of this, my front bumper is now bulging out near the side marker which I think is a result of the before mentioned plastic rib being pulled out. Has anyone experienced this before?
Thanks.
le'1le is offline   Reply With Quote
Old 06-13-2018, 08:42 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 128K! - All work by me...
Old 06-13-2018, 10:53 AM   #3
le'1le
Drives: Future 1LE
https://photos.app.goo.gl/kUTAz48acwDFZP8z6
https://photos.app.goo.gl/3U1Nw4dWeH382AGf6
Old 06-17-2018, 10:05 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I'd say your going to need a new front fascia.
Orange Krush II
1LE Front sway bar with DSE Sway Bar Links, Trailing Arms and Toe Rods, Splitter, and Axles, 14/15 Heat extractor, shocks and struts, Suede Flat bottom Steering wheel, short throw shifter with the Pegasus rear poly shifter mount, diffuser with dual mode mufflers, ZL1 Rockers, Belly Pan and pedals, Z/28 Intake, UCA Bushings,and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, C7 Z06 Vented Piston Calipers with CTS-V Rotors, PAFDT Solid Cradle bushing, 32mm JPSS Rear Bar, and Skip Shift eliminator. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 17/8 LTs.
Old 06-19-2018, 09:24 AM   #5
wakespeak
wakespeak's Avatar
Drives: 2013 2SS LS3/NPP
I had decent luck with epoxy (Home Depot) to fix the mounting loops when my fascia got ripped forward after a body shop left out the lower bolts and the droop allowed it to get caught on a parking curb. I used wax paper and clamp to fill the sections in the mount points that got cracked or ripped out, then drill out as necessary.
I also had the lower rib as you described on one side broken. I have not taken the time to try and use epoxy there.
NPP, 1LE track pack, ZL1/1LE shifter, Apex catch can, 1LE oil separator, CTSV 6-piston front upgrade,1LE strut tower brace. Gen6 1LE wheels. Pegasus Aluminum Rear Cradle Bushings. Z/28 upper control arm bushings. JRE built 3.91/TrueTrac diff. JRE tune for stock engine.
wakespeak is offline   Reply With Quote
Old 06-19-2018, 07:08 PM   #6
gringo
gringo's Avatar
Drives: Camaro
You can use two part urethane 3M adhesive. The kind they use to fill and repair semi rigid urethane.
gringo is offline   Reply With Quote
Old 06-19-2018, 07:17 PM   #7
2015Black1SS
Drives: 2015 Camaro 1SS Black
This is correct I had a similar experience ... I had a 0.5mph collisions w a curb and my splitter cracked . No big deal buy a new splitter . until further examination when I realized the fender liner broke away from the front bumper cover .the bumper cover tabs ripped off with the liner so I couldnít just replace the liner.. so long story short new bumper cover ,splitter, paint and liner .hopefully you donít have bad luck like me though ..
2015Black1SS is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
