09-14-2012, 10:36 AM | #1457 |
I'm in high 3rd gear crossing usually
09-14-2012, 10:47 AM | #1458 | ||
INJACC
Drives: 2010 CGM 2LT/RS AUTO Join Date: Jan 2009
My best times are always in D mode....S mode is like .1 - .3 difference. Just bought the Air Scoop for my CAI...once installed I will go back to the track & try agai this time in colder weather.
Member of 'Club Elite' #70
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty CAI - Cold Air Inductions / VMAX TB / Trifecta Tune Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels / Oracle Afterburners / Oracle Concept SMD Side markers Complete SS Brembo Brakes Set Last edited by RickRay; 09-14-2012 at 01:08 PM. |
09-14-2012, 10:57 AM | #1459 | |||
having FUN now 13.66@101
You're Welcome. Godd luck. Next time plan better....LOL..... less fuel in tank.Leave traction control on. You want all the nanies on for the best results. Trust me, I have over 100 passes and have tried all cominations many times over. Now that said, I would do the burn out with th traction control off and get the tires hot. Quote:
All nanies on for the launch. Quote:
I am in 3rd gear crossing at approx. 6400 rpm's at over 100 mph. see above
09-14-2012, 01:13 PM | #1460 | ||
INJACC
Hi Vince, Need to know if you have different tunes for different fuel? I always used Super (91 Octane) since May 2009...(the odd times 93/94) My exhaust seems to be getting more black!!!(pipes) Since the last Tune Update!!! He wrote back: You don’t need different tunes for different fuel. - Vince Geglia Trifecta Performance, Inc
2LT/RS Auto / Solo HFC / Solo Mach X-LLT J-Pipe / JBA Headers Shorty CAI - Cold Air Inductions / VMAX TB / Trifecta Tune Hotchkis Max Strut Brace / Blade Dovetail Spoiler / Elite Catch Can ACS T3 Hood Ports / T2 Bumper Ports / T2 Splitter / ACS T1 Led Light Kit ACS Rockers / ACS Composite Hood Liner / ACS Upper Rear Quarter Ports ACS Front Wheel Mud Flaps / ACS Rear Wheel Mud Flaps / Vitesse Throttle Controller Pedders Drop Suspension / BMR Lower Control Arms / Style 41 ZL1 Wheels / Oracle Afterburners / Oracle Concept SMD Side markers Complete SS Brembo Brakes Set |
09-14-2012, 10:28 PM | #1461 | |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
09-14-2012, 11:31 PM | #1462 |
So I ran a 14.454 tonight.... not too bad im guessing
09-20-2012, 01:03 PM | #1463 |
Drives: 2010 Camaro 2SS/RS 6MT Join Date: Apr 2010
What do you guys think about running these on a set of 1LT rims?
http://www.hinsonsupercars.com/p-942...l-2454018.aspx |
09-20-2012, 02:19 PM | #1464 | |
Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
09-20-2012, 02:31 PM | #1465 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
But would that work if they are a pure drag day wheel and tire combo?
09-20-2012, 06:58 PM | #1466 | ||
These are the only drag radial I could find that would fit a 1LT rim, which remember are the lightest stock rim at 23 lbs. Problem is that you cant run anything wider than a 245, BUT I think these will actually work quite well for us. Especially bolt on/nitrous cars. Quote:
With these out back you'll get a simulated higher gear ratio. In addition I think traction would be great if you ran the stock 55 size up front. Because they lower the back 1.5 inches, the weight of your Camaro will shift backwards and apply more weight onto these radials. This should provide more traction. As you roll down the track too you won't spin as much as you gain momentum and more weight is shifted towards the back of the car. This is what a 45 looked like on my car, the 40 will essentially look the same. |
09-20-2012, 08:15 PM | #1467 |
I don't really care what it looks like at all. If it gets the job done, I'm all for it. I cut 2.3 60fts. It would be great if I can at least get a 2.0-2.1 out of these. Anything less and that's just icing on the cake. I think my uncle has an extra set of lt rims so I might just get 2 from him and mount these tires on it.
09-20-2012, 08:50 PM | #1468 | |
I cut a 2.0 60ft in my 6MT when I was bone stock with the 20s, I would expect a sub 2.0 with these, hopefully a 1.85 or 1.9. The simulated gear + traction should help me finally get into 13s. With the set up I had I trapped 101.5 but didnt hook at all netting a 2.2 and 2.3 60ft and a 14.4 1/4 time. If I can cut a 1.9, I should run a 13.6 with my set up. Maybe faster now that I can shift much quicker. All with just an intake and cut outs on stock exhaust. So let me know about those 1lts! |
09-20-2012, 10:06 PM | #1469 |
Just asked my uncle, looks like he wants to wait a little longer to see if he buys another camaro. If he does, he's putting those on it. Either way, if I hear he wants to sell, you'll be the first I contact. I so want to do this now! The simulated gear ratio is something I hadn't even thought about.
09-20-2012, 10:33 PM | #1470 | |
My only concern for this is if a 245 radial will be enough for us to hook. I'm confident though as I've seen other cars with similar or greater whp hook with a 245. At a minimum it will be much better than any stock tire. |
Similar Threads | ||||
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List | Merc | Dragstrip and Launch Techniques Discussion | 250 | 04-01-2014 10:40 AM |
Does the v6 have enough power? | cstproductions | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 305 | 08-29-2012 09:27 PM |
Modern Camaro Performance - Lowest Prices Anywhere! | PartsTaxi.com | Sponsor Announcements / Giveaways / Contests | 0 | 11-03-2010 10:50 AM |
Modern Camaro Performance Parts - www.PartsTaxi.com | PartsTaxi.com | Sponsor Announcements / Giveaways / Contests | 0 | 10-06-2010 04:26 PM |
Official 1/4 Mile 2010 Camaro Stock Pirelli's Fast List | GQ4Life | Dragstrip and Launch Techniques Discussion | 17 | 07-07-2010 12:31 PM |
