Old 05-25-2024, 01:24 PM   #1
Powerlovers
Drives: 2013
Lambda Gauge
Hello everyone, i have a question regarding lambda gauge when i cruise usually its yellow lights and .95 to 1.0 when i speed the yellow lights turn green and reach to .70 or .71 is it normal or something wrong?
Thanks in advance
Powerlovers is offline   Reply With Quote
Old 05-25-2024, 04:48 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
The engine will go into "power enrichment" at some point (based on throttle input, RPM's, etc.) which is basically just adding extra fuel for more power, cooling, etc. Every engine is different but 0.7 seems low, which is ~10.3 AFR, whereas from what I understand most engines "prefer" somewhere between 12 and 13 (0.82 - 0.88 lambda). But to answer the question, yes, it is normal to see a lower lambda when having fun.
KillboyPowerhead is offline   Reply With Quote
Old 05-25-2024, 06:31 PM   #3
bsn
Drives: 2013 ZL1
If you have modifications a lower lambda (rich) under heavy load is much safer than running lean. As long as its running good and your plugs aren't fouling then your good.
bsn is offline   Reply With Quote
