06-08-2017, 07:01 PM | #1 |
Drives: 2010 Camaro ss Join Date: May 2017
2010 ss auto mis fire
Need some help once again. Have a 10 ss auto everything is stock except slp loudmouth exhaust. It's always idled a little weird but now it's bad. Just replaced ignition coil 1 which was bad all others are fine new wires and spark plugs. It's misfiring bad no codes. Had a code which was for the coil replaced now gone. Has a strong cat smell and sputters in park and any pulling gear. Any thoughts?
06-08-2017, 08:06 PM | #2 |
Drives: 2011 ss 2ss auto camaro Join Date: Mar 2015
Could be clogged cats
06-09-2017, 06:25 AM | #3 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
Could be a bad plug....just because it's new doesn't necessarily mean it's good.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
06-09-2017, 07:27 AM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
How many miles?
Check all plug wire connections...again. clean maf....check all intake/vacuum hoses......even 02 connections. Eliminate all the simple stuff first.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
06-16-2017, 05:05 PM | #5 |
Drives: T Join Date: Mar 2015
make sure those plug wires click for connection
06-20-2017, 11:05 PM | #6 |
Drives: 2010 Black 2SS RS A6 Inferno Join Date: Nov 2009
could be a lifter stuck
[SIGPIC][/SIGPIC]2010 Camaro Black 2SS/RS A6 Inferno Interior Polished Rims, Sunroof
Born 11/19/09 mods: 20% tints Borla Atak cat-bak Roto-Fab intake amber footwell, dome, and trunk lighting(AAC) Decepticon Gas door Led Taillights (technostalgia) |
06-24-2017, 07:05 PM | #7 |
Update on car. Fuel pump was going bad replaced that. Had fuel injectors cleaned and needed a update on the ecm. Car now runs and idles smooth no mis fires.
06-25-2017, 04:10 PM | #8 |
Car is still running and idling smooth check engine light just came on put a reader on it and get p0171 p0174 running lean on bank 1 and 2 any ideas. Was reading could be a MAF. Showed no leaks in exhaust or vacuum from smoke test
02-08-2019, 05:58 PM | #9 |
Drives: 2010 camaro ss Join Date: Feb 2019
So what was the problem? I just got the same codes p0174 p0171, pls share.
03-01-2019, 05:40 PM | #10 |
Drives: 2013 ss2 vert l99 Join Date: Apr 2017
Clean your mass air sensor.. alternatively you can disconnect the mass air sensor (car off first) and start the car.. it should run in speed density mode.. if it runs good and the codes don't come back then you have a dirty/bad maf..
