Old 11-12-2017, 09:36 PM   #1
KGoddard
KGoddard's Avatar
Drives: 2013 Camaro 2SS/RS
18" slick??
Is anyone running these? Does anyone know if they are bias ply?
http://www.mandhtires.com/M-H-Racema...8#.WgkSryNOlnE
Sent from my Pixel using Tapatalk
12.3 @113MPH - Full Bolt-Ons w/ Nitto 555r on 18" wheel
KGoddard is offline   Reply With Quote
Old 11-12-2017, 10:27 PM   #2
Bo White
Bo White's Avatar
Its a new tire so doubt anyone has them yet. I want to try a set myself.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 11-13-2017, 05:16 AM   #3
KGoddard
KGoddard's Avatar
Did a little research, they are bias ply. I just might have to buy a set and try them out next season.
Old 11-13-2017, 06:41 AM   #4
Bo White
Bo White's Avatar
Yes they are bias. Sorry forgot to put that in my post.
Totalled:
Old 11-13-2017, 05:12 PM   #5
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
So can we run that tire with our stock front tires?
From what I've heard you should not run bias ply rears with radials on the front.
I'm not exactly sure how it affects the handling of the car?????
stratman2SSRS is offline   Reply With Quote
Old 11-13-2017, 05:44 PM   #6
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
that's if you drive it on the street..1/4 is cool...
Old 11-13-2017, 07:11 PM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
It's about damn time!!
Old 11-14-2017, 03:21 PM   #8
Bo White
Bo White's Avatar
I daily with a radial/bias mix on my car. Been doing it for over a year now. Its not recommended though.
Totalled:
Old 01-22-2018, 07:22 AM   #9
BandRcAMARO
Drives: 2010 Camaro 2SS/RS
Do you think if I ran bias blys slicks on my rear 17 inch rims and skinny radials up front on my 18 inch rims I will be okay at the strip? 1/4 mile btw
BandRcAMARO is offline   Reply With Quote
Old 01-22-2018, 09:56 AM   #10
frankwjr
frankwjr's Avatar
don't matter rim size..tire height is key...too much front/back freaks out the ABS and have to pull fuses...I have a 18" rear and looks like I may have to run a 17" skinny up front but will make sure the dia is 28" like the rears are...I personally don't like pullin fuses.
btw - this being a bias a tube is needed correct? therefore peeps can use rim screws to stop the slip....can't do that on radials...peace out
Old 01-22-2018, 10:12 AM   #11
KGoddard
KGoddard's Avatar
From what I've read on other forums no tube is needed. But if someone could verify that would be great
Old 01-23-2018, 05:45 AM   #12
Craig B
Craig B's Avatar
Drives: 2013 1LE
Usually you don't need a tube with a slick but, I do like running tubes on a heavy cars or fast stuff. It can help the sidewall a bit. On a 4000 lb tank like a Camaro it would be a good idea.
Craig B is offline   Reply With Quote
Old 02-20-2018, 12:03 PM   #13
KGoddard
KGoddard's Avatar
For those interested. I bought a set of these last night so I'll be updating with lots of pics and info.
Old 02-20-2018, 04:06 PM   #14
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
