08-30-2015, 12:10 AM | #1 |
Drives: 2013 2SS 1LE NPP GBE Join Date: Sep 2012
Exhaust noise deferment
Hi all. I have the NPP exhaust on my SS with mid pipes that eliminated the resonators. Now the car is louder than I expected and I fear at Laguna Seca I'll get black flagged by exceeding the 92 decibel limit. Any tips on how to quiet the noise without changing the exhaust itself?
I'm particularly concerned with the sound booth on the right between (I think) turns 5 and 6. -CRT Sent from my iPad using Tapatalk
08-30-2015, 12:23 AM | #2 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
Keep your exhaust valves closed. Might need a M2W switch or one of those old headlight relays. Or just some good old fashioned creativity!
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
08-30-2015, 02:05 AM | #3 |
Drives: 2010 SS RS Join Date: Apr 2009
A local lotus Elise put on a 90* down pipe adapter on the tip. It seemed to help a little, but our warnings at 98 dB. Disqual at 100. 50' from track straight where cars would open up. Solo2. I've gotten a couple warnings at 98, but never exceeded. Considered swapping mufflers for events? I have an OE SS axel muffler tailpipe I'm going to try swapping with my ARH mufflers. Hoping the OE chambers change the tone and soften it a little bit. LT and FI makes the car sound angry.
Otherwise, press less gas... That's what they told me to do. |
08-30-2015, 11:12 AM | #4 | |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
http://www.camaro5.com/forums/showthread.php?t=398397 modes Stock Always open Always closed |
08-30-2015, 11:13 AM | #5 |
Todd: i was thinking of that but it has a potential problem of draining the battery if you forget to leave it in a certain mode.
I may try a muffler shop and see if they can fab some inserts with a bend. -CRT Sent from my iPad using Tapatalk
08-30-2015, 11:52 AM | #6 |
Anyone have experience with super trap? http://www.supertrapp.com/product_se...t.asp?CatID=27
08-30-2015, 08:42 PM | #7 |
Brian I have cut outs that are always powered up and never had an issue. I just used the car today after sitting for a month, fired right up. The Forza has a switch so you can remove the power when the car sits. ADM makes one also.
http://lsa-conversion-store.myshopif...xhaust-control I would contact either of them on the battery drain, but it is probably only going to affect a car that sits a lot. The switch on the Forza is part of the controller, the ADM you could just add if you wanted.. any how I hope you are well and find the way to avoid the Sound Booth LOL. |
08-30-2015, 09:11 PM | #8 |
Todd, thanks. Appreciate it.
08-30-2015, 09:16 PM | #9 |
Which cutout do you have?
08-30-2015, 10:16 PM | #10 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
I swapped out the stock H for a resonated X pipe. It removed the higher pitch 'rasp'
I haven't had any issues with exceeding db levels. When I was at C5 fest, another car got flagged, so I assume I'm quiet enough. Alternatively you could safety wire the valves closed for track days
08-30-2015, 10:34 PM | #11 | |
http://www.camaro5.com/forums/showpo...1&postcount=30 Did you tuner do recommend a new tune after installing this? |
08-30-2015, 10:50 PM | #12 |
QTP at the rear. It gives me 6 outlets at the rear and is tucked in under the car so you have to look under to see it. Then ADM for the NPP. I can go 2 outlet, NPP stock operation, 6 outlet QTP, ADM always open, 4 outlet QTP open ADM closed., or 6 outlet NPP stock operation. I usually rolled all open, after headers I have some options.
08-30-2015, 11:07 PM | #13 | |
Geoff
08-30-2015, 11:41 PM | #14 | |
Got to say this is galactic. I would have thought this was more binary, meaning either flow via QTP directly into stock mufflers or flow out without the mufflers thus switching the QTP the other way. Are you saying the QTP allows flow both ways simultaneously and that how you get six outlets? -CRT Sent from my iPad using Tapatalk
Thread Tools | |
