Old 01-07-2011, 04:59 PM   #1
bee sting
bee sting's Avatar
Drives: 1997 30th Ann. Z28 & 2010 2LT RS
Question V6 header question.. looking for help picking a brand
I'm looking to buy either the Doug Thorley or the JBA shorty headers . my questions are..
1-Is one brand better than the other - power gains - fit.. etc ?
2- do you have to weld on the Doug Thorley headers at the collector ?
3- the JBA look like they bolt on at the collector ?
any help would be great ..thanks
bee sting is offline   Reply With Quote
Old 01-07-2011, 05:45 PM   #2
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
I looked at the shorties before I ended up going with the long tubes. This is what I've read. The JBA's do just bolt up while the Doug Thorleys need to be welded making the install easier. The JBA's seem to be hit and miss on the collector though. A lot have installed without any issues and some have collector sealing issues that have caused check engine lights. Do your investigating as I believe some have been able to get a better seal than others. They may be able to give you some pointers.
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 01-07-2011, 06:16 PM   #3
todrules
Rollin' Green
todrules's Avatar
Drives: 2010 Synergy Green Camaro
What long tubes you end up going with?
todrules is offline   Reply With Quote
Old 01-07-2011, 07:49 PM   #4
usa1camaro1969
I went with BBK's. When Jeg's originally added them to their online catalog they had a screw up and listed the ceramic-coated at the same price as the chrome(I want to say they were around $690 shipped). They come with hi-flow cats, O2 sensor extensions, gaskets, mounting hardware and do include the check-engine light that will come on within 50-miles at no extra charge. It was a bit of a pain to see that light in the dash until I decided to get the tune.
To the OP- If I were to make the decision I'd probably have gone with the DT's, but there are some fast v6'ers using the JBA's without issue.
-Ricky Bobby
Old 01-07-2011, 09:29 PM   #5
bee sting
bee sting's Avatar
i like the DT's myself but wanted to the install at home .i don't have a mig welder and so far all i have seen or heard you have to weld them on :( . I'll have to look into that issue of the JBA's not sealing up and be there was a run at the factory that was just a bad batch. maybe a part # to look out for . So if anyone else can give me input that would be great.
Old 01-07-2011, 09:38 PM   #6
VR Baron
SoCal Camaro5 Race Team
VR Baron's Avatar
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I have the D/T's and like them. Had my long time muffler shop install so welding was no issue. They are the better looking of the two, ceramic coated. Power I'd say is about the same on top but On the only two dyno graphs I've seen the D/T's are much better in the low to mid range. Sound about the same if you have an exhaust already, more low end bass sound after breaking in and a bit more growl up top.
VR Baron is online now   Reply With Quote
Old 01-07-2011, 11:45 PM   #7
Mankind
Whats a Millwright?
Mankind's Avatar
Drives: 2LT/RS SIM, 05 Wht Denali
It doesnt matter which of the two you choose, you will have to have welding done. Knowing now what i do i would have gone with the DT's. They are solid welds to the cats. JBA's have a stacker flage that has to be welded to the cats and then clamped to the header. Mine have been a pain at first and then a constant wait for the light to reappear. Took 4 or 5 tries at solutions before i got any milage without it. I dont recall seeing anyone with the DT's throwing a cel.
Mankind is offline   Reply With Quote
Old 01-08-2011, 04:19 AM   #8
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Another vote for DTs. You do have to get somebody to weld them on, but no CELs and they work and sound great. Nobody has had any problems with the headers themselves.
I did have an issue after installing them, the passenger side exhaust pipe was hitting the tunnel brace slightly causing a rattle, so I did have to replace that with the elite engineering one. I'm not sure if that was an install problem or what, but take it for what it's worth.
[B]
Old 01-08-2011, 02:09 PM   #9
bee sting
bee sting's Avatar
Thanks for the info... Sure wish there was a true bolt on shorty header for the V6 but it doesn't look that way. May still go with the DT's , Does the DT's tell you why the cut the factory cat pipes? maybe i can pull every thing off and take it to a shop and save a few $$. Also to the people that do have the DT shorties , did it hurt the coating on the header when it was welded to the cat?
Old 01-08-2011, 04:08 PM   #10
KMPrenger
KMPrenger's Avatar
From what I've ready, you need to remove the ceramic coating where the welding will take place.
Old 01-08-2011, 10:24 PM   #11
devildoc
devildoc's Avatar
Drives: '12 Toyota Tacoma Dbl
I would say screw the shorties and just save up for longs.
STANDING 1/4MI: 13.948@99.87
6600RPM HP/TQ Gains - 30.54HP/24.3TQ (NOT PEAK)
devildoc is offline   Reply With Quote
Old 01-09-2011, 12:16 AM   #12
esfkotaro
Drives: 2010 Camaro LS M6, Black with CGM
For those of you with LT's and MRTv2, does the in-cabin noise get obnoxious with regular daily driving? I figure getting shorties or LT's, either way, will cost me the same...since shortines require welding and I don't have the equipment\facilities for that anymore, I'd have to have the work done for me. LTs I could likely do myself...so cost of labor + cost of shorties ~= cost of LTs. Just have a hard time telling from recordings what the MRTv2 + LTs really sounds like.
2010 Camaro LS M6, Black with CGM Stripes
MRTv2 :: Injen CAI
Factory Spoiler Added
Coming soon (end of summer, hopefully):
JBA Shorties :: Hurst or MTI Shifter (undecided)
New 20" Wheels (undecided) :: Fogs :: GFX :: CF Heat Extractor hood :: Painted-On CGM Stripes :: G-2 Painted Calipers :: Painted Bowties
esfkotaro is offline   Reply With Quote
Old 01-09-2011, 02:44 AM   #13
muscle
Drives: Camaro
What was your check engine light looks like and sounds like.
muscle is offline   Reply With Quote
Old 01-09-2011, 07:56 AM   #14
devildoc
devildoc's Avatar
For me, in-cabin noise only exists when I want it to I keep my music on and I don't hear any drone at all. Of course it sounds nice and throaty when you punch the peddle.
It will do an in-cabin chime noise, and show up on both your speedo/tach and the info center. So you would probably have to hit clear all the time when you start the car. I have only had it happen to me once (not when I put my headers on)
v6 top speed ihc95 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 124 03-26-2010 09:23 AM
Header question flyby Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 10-28-2009 10:11 AM
Gas Mileage question: V6 vs V8 MyCamaro5 5th Gen Camaro SS LS LT General Discussions 1 09-10-2009 01:56 PM
