12-01-2009, 10:01 AM | #1 |
Drives: 2010 Camaro 2ss Join Date: Sep 2009
Catback instal help
Hey guys I wanted to know how easy it is to instal a cat back exhaust. It will obviously be my first time doing one and I just wanted to make sure i'm not in over my head. Going with stainless works if it makes any difference
12-01-2009, 10:20 AM | #2 |
its easy if you have a car lift, pull off stock exhaust in one piece then simply install the new catback it will bolt in no cutting or welding but i had mine tac welded when i was done installing in case you hit a pot hole they wont move.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s. |
12-01-2009, 10:39 AM | #3 |
Black Thunder
Drives: 2010 Camaro 2SS/RS Join Date: Oct 2009
You can do it with out a lift just much harder to do thats all. After you remove the old system install the new one and leave everything loose. After it is all in place start at the cat side and work your way back to the mufflers ajusting each pieace as you go and then tighten clamps as you work your way back. Sometimes it takes several ajustments to get it all correct. Also be very careful to make sure the car is raised off the ground in a safe manner. Before I got my lift I always used good jack stands and also left the jack in place just for good measure.
Similar Threads | ||||
Borla Sport Catback Exhaust Video | LyssaRaen | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 01-09-2010 11:13 AM |
DIY : Install catback on 2010 Camaro SS | Nine Ball | Camaro DIY & HOW-TO instructions & discussions | 3 | 08-09-2009 04:36 PM |
KooKs Headers and Corsa Catback will it need tuning??? | JJ2010 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 18 | 07-12-2009 04:57 PM |
Borla Headers and Catback / Catback available now | CWI | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 6 | 04-10-2009 11:46 PM |
questions about catback exhaust | babyjulie83 | Camaro Price | Ordering | Tracking | Dealers Discussions | 11 | 02-10-2009 01:52 PM |
