07-06-2022, 09:49 AM | #1 |
Drives: 20 ZL1 m6 Join Date: Apr 2022
Nitto nt555rll size
I’m looking to keep my stock front gy tires and change out the back with some nittos. Can the 315/35/20 fit the stock wheel and not rub the fender liners and also will it mess with the stabilitrack being slightly different height? Any info would be appreciated, getting the car back next week and it will be FBO heads and cam so need something better for street driving I have Hoosiers for the track but don’t want to waste them on the street.
07-06-2022, 09:56 AM | #2 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
For a stock ZL1 wheel you will want a 305/30/20. 315/35/20 will be too tall vs the front tires.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
07-06-2022, 09:58 PM | #3 |
07-08-2022, 11:38 AM | #4 |
Drives: '20 ZLE Join Date: Jun 2020
A few months ago, there wasn't a single 555Rii anywhere. Are they in stock again?
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. |
07-09-2022, 08:43 AM | #5 |
07-09-2022, 11:04 AM | #6 | |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Going to start looking for alternatives.
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
07-09-2022, 11:30 AM | #7 |
Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Same here. I really wanted to give the NT555R2 a try, but ended up going with the R888R. I’ve been impressed with them so far, although they’re not the quietest tire in the world…
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors, LPE BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
07-12-2022, 10:24 AM | #8 |
I seen them in stock the other day and now they are out of stock again.
It looks like if you order from Summit racing they will ship in 2 weeks.
2016 NFG 1SS A8
07-26-2022, 12:11 PM | #9 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Anyone have experience with the NT555RII?
If they really do offer a tire you can use in the rain with traction of the 555R then I am very interested
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
Tags |
315 35 20, nitto, tire size, tires, wheels and tires |
