Old 04-12-2018, 03:49 PM   #1
Rock on
Rock on's Avatar
Drives: black 2011 2ss
15” conversion and 325 50 15 fitment
I haven’t been on here for awhile but I thought this would be beneficial to anyone considering this mod. It all started last year when my wife bought me an lsa supercharger, my car was already heavily modded , cam ,headers , stall. I had Jordan at JDP install supercharger, fuel pump, injectors, solid subframe mounts, tune. Traction on street tires is now nonexistent. So I ordered Bmr drag suspension and Carlyle Racing 15” brake kit. This was pretty straight forward but you do have to cut the hole larger where the shock mounts I went with Carlyle Racing because of price and you keep your E brake. Also did the BMR anti roll bar
FASTER THAN A SPEEDING TICKET 2011 cammed 3600 stall LSA super charger. 68 cammed 2800 stall 4/11 posi
Rock on is offline   Reply With Quote
Old 04-12-2018, 03:54 PM   #2
Rock on
Rock on's Avatar
For the wheels I went with Weld 15x10 7.5 backspace tear weld 17x5 front
Old 04-12-2018, 04:02 PM   #3
Rock on
Rock on's Avatar
The front tires are M&H 28x4.5 radials rear are Micket Thompson ET Street 325/50 R15
Old 04-12-2018, 04:08 PM   #4
Rock on
Rock on's Avatar
In order to get these tire to fit you need to trim your inner fender liner, this is easy trace your tire with your car off the ground , deeply scratch with a razor knife and they will snap off where you cut
Old 04-12-2018, 04:12 PM   #5
Rock on
Rock on's Avatar
Then you will need to grind off part of the brake line brakes on the inner fender well and relocate the brake line . I used a hose clamp from ace hardware
Old 04-12-2018, 04:16 PM   #6
Rock on
Rock on's Avatar
On the passenger side you will need to use a flush mount screw and bend the tab in that holds your fuel tube
Old 04-12-2018, 04:21 PM   #7
Rock on
Rock on's Avatar
You will also need to tie back you E brake line I still am not satisfied with mine yet (zip tie) also where the crush washer is on the caliper the brake line needs to be turned inward
Old 04-12-2018, 04:26 PM   #8
Rock on
Rock on's Avatar
Don’t even bother with stick on weights to balance the rear tires there is almost zero space between the wheel and the lower control arm . It will spin in the air but on the ground it won’t clear
Old 04-12-2018, 04:31 PM   #9
Rock on
Rock on's Avatar
The front wheels are easy just cut off the roller skates. My calipers need paint anyway so I just cut them installed with a sawza
Old 04-12-2018, 04:33 PM   #10
Rock on
Rock on's Avatar
Test and tune this sat
Old 04-12-2018, 07:59 PM   #11
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Almost exactly what i have, except i have the carlyle lower control arms.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 04-12-2018, 08:27 PM   #12
Rock on
Rock on's Avatar
How did you secure your E Brake cable
Old 11-25-2018, 10:51 AM   #13
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
You could try sticking the weights on the spokes, inner side.
I always tell folks not to tell the tire shop not to put the weights on the barrel, they all get knocked off.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 05-14-2020, 11:14 AM   #14
wckdbad
wckdbad's Avatar
Drives: 2014 SS
Thanks for the details, I completed my conversion this winter and hope to get the front wheels done by fall. I went with the BMR conversion although that does require the parking brake delete....
wckdbad is offline   Reply With Quote
