06-16-2020, 04:10 PM | #1 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Upper door speaker
Anyone change them out for something a little brighter sounding? Anything out there decent to replace the factory BA ones? And how do you remove it without snapping anything off?
UPSTATE C5 MEMBER
06-16-2020, 04:29 PM | #2 |
06-16-2020, 07:06 PM | #3 | |
UPSTATE C5 MEMBER
06-16-2020, 08:09 PM | #4 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
You can... open the door and use a small flat head from the side closest to the door handle to pop it up then the front will come out.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
06-17-2020, 03:53 PM | #5 |
Cool, thanks! Now to find the meanest tweet to throw in it!!
UPSTATE C5 MEMBER
06-17-2020, 06:48 PM | #6 |
ILSQ
Drives: '13 2SS/RS Join Date: Feb 2017
Any tweeter from Focal will be brighter...
Way too many mods to list, and just getting started...
06-20-2020, 07:41 PM | #7 |
Drives: 2011 2SS/RS Join Date: Feb 2016
You forgot the word extremely
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
06-22-2020, 01:00 AM | #8 |
Brighter, you'd also need a lower ohm tweeter.
The door and tweeter are paralleled together. If the door speaker is 2-ohm, and the tweeter is 2-ohm, then the load is ONE ohm. You would need to find a 1-ohm tweeter to brighten it up "extremely." Also, if the door speaker is 4-ohm, and the tweeter is 4-ohm, then the load is TWO ohms. I know the Boston Acoustic speakers are 2-ohm. The plain factory speakers are 4-ohm. Front plain are 20 Watts, the BAs are 50 watts. If you want brighter all the way around, ditch the 4-ohm setup, and get the Boston Acoustic speakers. They're a direct drop in, and are cheap on eBay. So, going from the 20 watt plains, at 4-ohm, putting in the BAs at 2-ohm will almost be 40 watts equivalent output. |
