06-16-2014, 11:33 AM | #1 |
Drives: Synergy green camaro ss Join Date: Jun 2013
Car misfiring 2,000-3,000 rpms no code
I've seen a thread about this before but I don't think the problem was answered. I have a 2011 Camaro ss auto
Ls3 conv big cam full exhausts tuned by mike lavigne 150 shot of juice the car basically sputters n pops (back fires) under half throttle load between 2,000-3,000 rpm after that it runs like a champ I've pulled all plugs out thinking the nitrous might of burnt one one changed all wires just rolled 40k miles on it Wot the car will not miss a Beat it's just half throttle |
06-16-2014, 11:44 AM | #2 |
And again this exhaust pop happens when I'm half throttle not when I'm letting off the throttle
06-17-2014, 08:12 PM | #3 |
Bump
06-19-2014, 08:23 AM | #4 |
Anyone??? Tried fuel injector cleaner still no go different gas station still same crap
06-19-2014, 08:25 AM | #5 |
Drives: 2014 2SS L99 Join Date: Mar 2014
I'm still trying to figure out how you have a LS3 automatic.
06-19-2014, 08:49 AM | #6 |
06-19-2014, 09:24 AM | #7 |
Plug in a scanner and see which cylinder is misfiring. It will have to be a good scanner though, not the cheap code reader from Advance or AZ. Your tuner most likely turned off the individual misfire codes and unless you have multiple cylinders misfiring, P0300 will probably not set.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
06-19-2014, 11:59 AM | #8 |
Ok thanks I'll do that right after lunch see what it says
06-19-2014, 12:45 PM | #9 |
No trouble codes to b found...
Could an exhaust leak by the muffler cause this ? |
06-20-2014, 08:29 PM | #10 |
An exhaust leak by the muffler? No, to far downstream. Your going to have to go to a shop with a real scanner that can view the misfire data stream. This is completely different than looking at the codes.
06-21-2014, 02:09 PM | #11 |
Ok man will do thank u
06-27-2014, 09:08 PM | #12 |
army life
Drives: 2018 hyper blue zl1 Join Date: Feb 2011
I had a similar problem found my right side 02 sensor melted on the headers no check engine codes misfiring shuttering but at full wot drove good check your 02 sensor wires
Mods: lingenfelter 15% overdrive pulley, ATI balancer, kooks headers, DSX low side aux pump, DSX flex fuel, GPI stage 2 cam, trans tune, cat delete, rear seat delete, rotofab cai
