09-06-2016, 06:46 AM | #1 |
Hows my head look
Well I got my head back from the machine shop. They was able to put new seats in and checked it for cracks. Said all was good. I'm waiting on my exhaust valves.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/ |
09-06-2016, 06:53 AM | #2 |
Holy crap how much did they remove???
09-06-2016, 06:58 AM | #3 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
I just threw up in my mouth...sorry...
09-06-2016, 07:48 AM | #4 |
Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
Uhhh yeah...........no. I'd be installing a new set of GMPP ported castings or at the very least a clean set of used ones before ever putting that back on.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
09-06-2016, 08:51 AM | #5 |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Do not run that head like that.
You have tons of nooks and ridges and peeks everywhere. This is going to cause hot spots and you're going to have serious issues with detonation on that cylinder. You need to get all imperfections welded in and than the entire chamber will need to be CNC'd after to fix that head properly. Than you need to mill the other head thats not damaged to match this one since it looks like they milled a TON of the head surface down.
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
09-06-2016, 09:23 AM | #6 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
It will run but i wouldn't use it.
09-06-2016, 10:05 AM | #7 | |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
09-06-2016, 10:55 AM | #8 |
Drives: 2018 GT350 Join Date: Nov 2011
Was this done by a child?
Off to the Dark Side
09-06-2016, 11:03 AM | #9 |
Drives: 2015 1LE Join Date: Oct 2015
You cant be serious, just get a replacement head for crying out loud.
09-06-2016, 11:12 AM | #10 |
Drives: 2011 2SS/RS M6 Join Date: Oct 2015
I wouldn't have even wasted my money on taking that garbaged out head to the machine shop in the first place. Like said before, you're going to have issues on the cylinder if you use it.
09-06-2016, 11:32 AM | #11 |
Could have been done better.
The heads on my car looked like that. Now you can't tell anything was done and just took .005" off for a clean up pass.
09-06-2016, 01:09 PM | #12 |
GPI Sales Consultant
That's insane - are the serious about sending you out the door with that going back on the car? Like it's been stated, that's a nightmare of spark knock waiting to happen. I'm guessing this a boosted car (turbo in the background) - so I'd think you'll compound that issue. Not to mentioned they've easily raised the compression a few tenths. How long till you think you have trouble with one of those seats again?
I'd return your large paper weight and get your money back. What's the back story on the failure here?
Got a question about a GPI product? Feel free to shoot me a message! |
09-06-2016, 02:18 PM | #13 | |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
It even has dents past the fire ring, or it looks like it in that picture. Not saying it couldn't have been fixed but one new head would have been cheaper than to fix it (the correct way) as they would have to weld it, mill it, and port it. Stock head it just isn't worth it. |
09-06-2016, 02:37 PM | #14 |
Looks like an expensive paperweight.
I wouldn't run that on a bone stock car, let alone something pushing for 1000+.
Nick
Corvette Z06 -1200ish rwhp |
Thread Tools | |
