Old 05-02-2010, 10:08 PM   #1
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Question on coil-overs for the pros...
Some state an adjustable drop over 1.5". However, alignments will probably be necessary once dropped lower than this. Are alignment places able to handle such a low drop(heard stories...). And if you constantly make adjustments, will tire/struts wear out sooner, while probably needing an alignment again every time?
..like the flexibilty of the coil-overs, but will it continue to drain my wallet?
Old 05-02-2010, 10:23 PM   #2
Rob@WretchedMS
Drives: His Wife Crazy
Not sure i completely follow.
Any time you install a coilover on to the car you will need to do an alignment, regardless of the amount of drop.
the front won't be to big of an issue, as there should be enough adjustment to get it where it needs to be.
The rear is more complicated, the lower you go in the rear the more negative camber you get, and the less the stock adjusters will adjust.
Any time you make height adjustments you will change the toe and camber, so you should have it re-aligned when you do this.
typically most find a spot they like and leave it there once it's set.
Rob@WretchedMS is offline   Reply With Quote
Old 05-02-2010, 10:32 PM   #3
mlee
mlee's Avatar
Drives: 2019 Crush ZLE
Dumb question but why do coil overs (set it and leave it) if a drop spring gets you the same thing. Is it for a smoother ride??
Old 05-02-2010, 10:35 PM   #4
Rob@WretchedMS
you have the ability to adjust it if needed, height as well as dampening level.
Coilovers typically allow for a much stiffer damper.
Old 05-02-2010, 10:39 PM   #5
Xtreme Innovations & Fab
Drives: 2010 Camaro
Yes, you will have to have it aligned and if all the specs. are met you shouldnt have to worry about a realignment again unless you hit something. About the alignment shop, just make sure you do your homework and find one that has worked on these type of projects before. If you have any other questions please give me a call..
Xtreme Innovations & Fab is offline   Reply With Quote
Old 05-02-2010, 10:40 PM   #6
mws444
mws444's Avatar
Drives: 701 RWHP Lingenfelter/Pedders Beast
I also hear a lot of guys wear out their struts with just a lowered spring. Why not just step up and do it once, and gain the adjustability?
Lingenfelter forged balanced and blueprinted LS3, Maggie TVS 2300 LPE 9.5" Rearend 3.73,LPE dual disk clutch,10/14 rib belt drive,
MTI shifter,RPM Level VI,Corsa stainless cat back, Racing Brake Rotors, LPE calipers, LPE twin fuel pumps, American Racing long tube headers, GT9 cam Port and polished heads and an ADM majic tune.
701 RWHP,Fully Pedderized w/complete bushings and Sportsryder Supercar Remote resevior coilovers.
CCW 505t's Nitto Invo's and DR's
Beware of the LPE Brotherhood!
mws444 is offline   Reply With Quote
Old 05-02-2010, 10:43 PM   #7
Rob@WretchedMS
are you suggesting that he can adjust the height with no concern to alignment changes, and should only ever need an alignment if the hit something?
Old 05-02-2010, 11:00 PM   #8
Drives: 2010 Camaro
The way I undestood it , is once he went lower than the 1.5" drop there is going to be on going issues with things failing , like tires and struts. So what I was saying is if the car was lower past the 1.5" drop and all of the specs. were in place, he would have no problem. Nobody said anything about changing ride heights multiple times. Yes, if you move the ride height a bunch ,you will have to have it realigned.
Old 05-02-2010, 11:06 PM   #9
Rob@WretchedMS
this thread is about coilovers, so struts are removed and can't wear. What other things are you thinking would be a high wear item?
He actually does specifically ask about changing heights,
Our coilovers do not limit the travel with changes in ride height, maybe this is where we are getting confused.
Old 05-02-2010, 11:20 PM   #10
Drives: 2010 Camaro
Struts ,coilovers , whatever, point is he said making changes , not ride height changes. When he said (making adjustments) this could multiple changes for all we Know. Im not going to argue with you over something that he didnt specifically say or did say. I was just trying to help, and your going places with this you dont need to go.
Old 05-02-2010, 11:27 PM   #11
Rob@WretchedMS
sorry if i came across wrong, it's just a discussion.
your answer didn't make sense to me and i just wanted to clarify.
to be clear.
Dropping a car 1.5" with struts can be an issue long term, especially if you cut the bump stops.
Dropping a car 1.5" with most coilovers will not have a negative effect on the wear of anything if properly aligned.
I did make an assumption that adjustments referred to height adjustments, since the post was about the amount of drop.
Again, i'm sorry if you took my posts as an argument, they were not, they were only to clarify your posts since they didn't make sense to me when i read them,
have a good night
Old 05-02-2010, 11:36 PM   #12
mlee
mlee's Avatar
I might have confused things by adding my spring vs. coilover question.
I know the main benifit of a coilover is being able to adjust it. But I also know if I have to align it every time it will most likely be set and left.
This is why I'm asking what OTHER benifits are there w/ coilovers. One answer I get here, is wear on my stock strut would be greater with spings only.
Old 05-02-2010, 11:43 PM   #13
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
The benefits to me (as a consumer) is the ability to adjust dampening/rebound. I ride around with a stiffer-than-stock set up 16 clicks/19 clicks on my set up coilovers, but if for some reason, I feel the need to make the ride as cushy as possible, within 2 minutes I can have the coilovers responding differently by twisting 4 screw-like adjusters.
That and the fact that I can adjust my ride height, although every time I do I would need to get it aligned. If I go with a staggered set of wheels, I can drop the back slightly more than the front to keep the horizontal axis of the car even, etc. etc.
This is why I went with coilovers. Springs seem to be one height and you're set. Also, you can't adjust the the camber in the front without getting an adapter. With coilovers (at least my set), you have a small brace that's ready to accept adjustment screws and such if you're going for an advanced suspension setup.
Old 05-02-2010, 11:59 PM   #14
Rob@WretchedMS
The camber is adjustable from the factory both front and rear.
Camaro Pfadt Race Engineering Coil Overs PfadtRacing Wheels and Tires Talk Sponsored by The Tire Rack 16 03-29-2011 10:10 PM
Pedders Xa Coil Over for the Camaro Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 41 07-17-2009 05:44 PM
2010 Camaro PEDDERS EXTREME XA COIL OVERS ON HENNESSEY CAMARO! Info@PeddersUSA.com Wheels and Tires Talk Sponsored by The Tire Rack 75 06-20-2009 04:32 PM
Camaro needed for Beta test for our new Xa Coil overs Info@PeddersUSA.com USA - Great Lakes 10 05-13-2009 01:06 AM
Coil Overs or Air Bags? Bentley78 Wheels and Tires Talk Sponsored by The Tire Rack 7 04-16-2009 02:12 PM
