Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
![]() Drives: 2015 zl1 Join Date: Jan 2020
Pushrod question
So after getting heads on . Johnson 2110 lifter , ls9 head gaskett , I measure with the pushrod length checker . I came up with 7.36 that with Johnson preload already added of .035 . Pushrods only come 7.375 is the closest one . I know there’s a +.010 if variance that’s allowed . Which puts me tad over . Will that be a issue ? They do offer a 7.35 which puts me right at the max variance at -.010. Which direction should I go ? And if possible what’s the pros and cons . Thank you really appreciate any feedback
Evil Genius of Chevrolet
Drives: 2013 Camaro 2SS 2015 LaCrosse Join Date: Feb 2017
Definitely a question for Andrew at GPI. He's the guru around here with cams.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, 8 rib belt, Cam phaser, Corsa exhaust, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI Superdamper, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Speed Engineering headers, Stainless Works HF cats, and much more.
Talked to Johnson . They told me they would prefer to be on the tighter side , as aluminum motors when they get to running temp the lifters loose .015 of preload . They also told me they want me to measure all cylinders int/exhaust instead of the two I did on each side .
Makes sense. Measuring each cylinder is good practice too. Better safe than do it twice or get a new short block.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS LS3 Swapped A6 Join Date: Sep 2016
2010 CGM Camaro 2SS LS3 Swapped A6 - GPI LS3 SS1 .647/.638, (224/237, 112 +4) on CamMotion 8620 core, BTR Platinum .660" Dual Spring kit w/titanium retainers, CHE bronze trunnion upgrade, stock heads milled @ .015, Melling HV 10296 oil pump, TSP long tube headers (W/Catless Off-road Pipes), FlowMaster Outlaw axle back/X-Pipe, Stage 2 Ported Throttle Body, Vararam OTR CAI, Mike Norris Gen 2 catch can + GM 1LE clean side separator, 160º thermostat - Megan Racing adjustable coilovers (lowered 1.75"), Firestone Firehawk Indy 500s - Tuned by Ryan @ GPI via HP Tuners
#6 |
![]() ![]() Drives: 2010 2SS/RS Join Date: Oct 2018
No doubt about that, sounds like a real bundle of joy. I bet you only get them mixed up once, pistons and valves don’t appreciate cozy time much.
”Blue”ABM #2399 GM GFX, GM Heritage, GM dovetail. Silver Ice Rally stripes.
#7 |
I bet that would be a pita . I figured tho with the lifters have some travel , I think .200 of travel figures it would all
Work but , when i have time I’ll measure every single one . |
Thread Tools | |
