01-24-2023, 01:36 PM | #1 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
2013 Seats in a 2010
So I probably should have asked this before purchasing but I shouldn't have any issues putting 2013 seats in my 2010 Correct? Both are leather, heated, and power.
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's in the trunk / MRR 228 Wheels / BMR Springs / Moog Endlinks / R1 Concepts Rotors & Pads |
01-24-2023, 03:31 PM | #2 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I vaguely remember some post that some of the wiring connectors are different, but I don't remember any details.
01-24-2023, 07:47 PM | #3 |
Drives: 2011 Camaro ss Join Date: Jan 2020
You'll have to swap over and wire in the passenger seat track position sensor.
01-25-2023, 02:22 PM | #4 |
Ugh. I cant find anything on this. All of my searches discuss aftermarket seats. I guess Ill just wing it once I start the swap
01-25-2023, 04:54 PM | #5 |
It's on here. It's how I found out about it and learned how to do it. Read the threads, even if it's about aftermarket seats because it is in one of those threads. I just can't remember exactly.
01-25-2023, 07:17 PM | #6 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
This may be useful, start with the first post on first page though.
https://www.camaro5.com/forums/showt...=166968&page=2 |
01-25-2023, 07:22 PM | #7 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
Here you go. You have to dig through it because it is about putting a power track in a 2010, but step 8 and 9 talk about the sensor and later he confirms he had to transfer the position sensor from the manual track to the power track.
https://www.camaro5.com/forums/showt...ghlight=recaro
2010 SS - On3 kit with downpipe cutout, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
01-26-2023, 10:27 AM | #8 |
The link "Camarocracka" posted is the one I used when I did my seat. Worked like a charm and very straight forward. It made easier sense to me when I had both seats in front of me so I can see/touch exactly what is in the posts.
I think 12+ seats have power passenger seat, I'm not sure if anything additional is needed to make sure that works or not or if that is plug ad play . |
01-26-2023, 12:58 PM | #9 |
Thanks everyone! im a little overwhelmed skimming those links but im sure ill make it work. Im assuming the drivers seat and rear seats will bolt right in and then ill have a bit of a project with the passenger seat. It may make more sense when I have the new seat and old seat in front of me.
01-26-2023, 02:51 PM | #10 |
Focus on entries 2, 4, 6, 7, 11, 13, 14 and 17. They are the ones involved with the sensor switch. You basically remove the pin from the old seat harness plug and cut the other end of that wire from the old seat harness that goes through the sensor. Mount the sensor from the old seat on the new seat and then splice the wire and plug from the old seat harness to the new seat harness and insert the pin that is on the other end of that into the new seat plug at the correct spot. Clear as mud?
01-30-2023, 08:00 AM | #11 |
I picked up the seats this weekend. They are in my buddy's basement for now. Gonna be a springtime project. Drivers seat has a little tear so I wanna get that repaired before the install.
01-30-2023, 03:05 PM | #12 |
All this for red leather lol
01-30-2023, 06:52 PM | #13 | |
Drives: 2010 2LT/RS Join Date: Mar 2015
My 2010 has power seats in both the driver/passenger. I do not believe it is year specific unless it was a base model Camaro without power seats.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
01-30-2023, 06:53 PM | #14 |
2010 2LT/RS
