06-15-2012, 07:36 AM | #1 |
Speed Racer
Drives: 2022 LT1 Join Date: May 2012
Will 2011 LT Rims will fit 2012 LS1?
(*NOTE-talking about 1LS not LS1, lol)
As stated from reading through the forums, I gather 18" 2011 1LT rims will fit my 2012 1LS that has the stock 18" steel rims? And the stock tires will swap/fit also I believe. The reason I ask is I have the chance to get the 18" 2011 LT rims, as I am not to crazy about the stock 1LS steel rims I have. Assuming they fit on my 2012, what about the TPMS sensors. Will my TPMS sensors work with the LT rims? The seller does NOT have the original sensors. I don't want to go through the swap and have the TPMS not work or throw a code. What does this TPMS sensor attach to anyway? Thoughts? TIA - P.S. - Attached is picture of actual car/rims. He swapped them for another type. Last edited by BigVic; 06-15-2012 at 11:33 AM. Reason: added info, corrected ID10T error, lol |
06-15-2012, 08:23 AM | #2 |
Drives: 1LT/M6 Join Date: May 2012
if you mean the 1LT rims to a 1LS camaro...yes it it will work. but now if your talking about 1SS car with 1 LT Rims..that wont work!
06-15-2012, 09:37 AM | #3 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
Big Vic.....seeing as you have a V6 model car.....ALL of the stock factory wheels will fit and work on your car, the 18's, 19's, 20's and 21's.
06-15-2012, 09:44 AM | #4 |
Drives: 2011 LS White Camaro Join Date: Jul 2011
like every1 else is saying its a 1LS not a LS1 its comletely different lol. they will fit though .
06-15-2012, 10:20 AM | #5 | |
Delivered 05/20/2009
Drives: Black 2010 2SS RS Join Date: Apr 2009
Sensors attach to the valve stem on the inside of the rim. |
06-15-2012, 11:35 AM | #6 |
Speed Racer
Yes, I meant 1LS, not LS1.
06-15-2012, 03:22 PM | #7 |
Speed Racer
06-15-2012, 03:23 PM | #8 |
Speed Racer
...and thank you Coop Last edited by BigVic; 06-15-2012 at 03:24 PM. Reason: text error |
06-15-2012, 04:28 PM | #9 |
Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
I have some for sale if your interested with tpms sensors, pm me
06-15-2012, 10:20 PM | #10 |
I just did this to mine. I bought a base model 1LS. I found some 1LT wheels with tires on local Craigslist for $450. I bought those, then took them and car to tire shop. I had them take my stock black wheels off, take my tires and tpms and switch them to the 1LT rims. Everything went fine, and it looks allot better now. Proceed without fear.
2015 2SS RS A6 - Summit White
...and the trees are all kept equal by hatchet, axe, and saw............RUSH KC Chiefs fan since 1994 / ST. Louis Cardinal fan since 2001 / Dale Jr. Fan since 1999 |
06-15-2012, 10:21 PM | #11 |
Account Suspend...Right
Drives: Synergy LS & Vulcan 1600cc Join Date: Apr 2011
yes
