Old 08-29-2012, 09:20 AM   #1
Coop 2010
Delivered 05/20/2009
Coop 2010's Avatar
Drives: Black 2010 2SS RS
Water Spots on Stripes
100+ degrees and sprinkler at work went off. Spots will not come off, any suggestions? Have tried light buffing, didn't want to burn them.
Coop 2010 is offline   Reply With Quote
Old 08-29-2012, 10:28 AM   #2
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
gloss or matte?
Old 08-29-2012, 09:47 PM   #3
Coop 2010
Coop 2010's Avatar
Gloss
Thanks for the reply
Old 08-31-2012, 07:40 AM   #4
Todd@Autopia
Todd@Autopia's Avatar
Drives: 2010 Mazdaspeed 3
Try Chemical Guy's Water Spot Remover.
Old 08-31-2012, 11:41 AM   #5
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
This is something that I kind of stumbled upon, I used a little bit of rubbing alcohol on a soft cloth, at first it worked real good on the paint, then I used a little on the stripes, and it worked, I also follwed up with some turtle wax ICE, I have been using armorall extreme shield wax, but it leaves water spots but it does make for washing the car down easier and for getting the bugs off.
warren3537 is offline   Reply With Quote
Old 09-05-2012, 09:59 AM   #6
Adam's Polishes
Gloss
Its gonna depend largely on how bad they are... start simple with a little white vinegar and see if that will dissolve whatever minerals are there, be sure to only start this process if the stripes are cool to the touch and out of direct sunlight. Never let anything, especially chemicals or cleaners, dry on them. You can lightly clay the spots as well, just be very gentle as the possibility of 'marring' the vinyl is high and you don't want to put more damage in.
You can also try to polish lightly with a VERY fine abrasive (like our Fine Machine Polish or Revive), and see where it gets you. With the vinyl you just have to be extremely careful about introducing harsh chemicals b/c theres always the possibility of staining, discoloring, or damaging the stripe further.
Any chance you can get a picture of the issue?
Old 09-05-2012, 03:49 PM   #7
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Any suggestions for matte stripes?
Deke736 is offline   Reply With Quote
Old 09-05-2012, 07:09 PM   #8
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You could try the spot removers, vinegar, or the clay. Stay away from polish as it will shine up the areas you polish more than the matte surroundings.
I hate giving advice for vinyl because it's so easy to ruin it with the wrong product or application. I really just hate vinyl
[B]
Old 09-06-2012, 12:19 PM   #9
slicktempo
slicktempo's Avatar
Drives: 2011 Camaro
Clay bar?
slicktempo is offline   Reply With Quote
