06-16-2019, 06:22 PM | #1 |
Drives: 2012 ls3 Join Date: Feb 2014
Heads, worth it???
Wanna know what aftermarket head or just ported heads you guys are running in why?? And what rwhp?? I know our stock flow pretty good straight from the factory. Imo it looks like with the aftermarket head you can change the angle allowing better ptv clearance hence bigger cam options and also smaller combustion chambers so not so also increasing compression all gonna add up to more horsepower. Im asking cause it can be an expensive upgrade and want to start my head find now. So....
06-16-2019, 06:25 PM | #2 |
That's increasing compression with smaller combustion chamber without affecting flow rates
06-17-2019, 07:02 AM | #3 |
old school chevy rodder
Look to GPI and their max package. Other than that not the most gains and you wont get a bigger cam with stock flat top pistons with out fly cuts to make it worth it. Frankly claims of stock heads being ported making so much more power....not so much. Stock heads flow better than port bbc heads, you have to have the need for the flow increase with most its not that great a need...…...… So a small bore ls7 head flows a lot more changes the angle and then allows a actually milder cam that multiplies by the ratio of the rocker and also allows a better intake the airforce.. Just a couple thoughts. If you have to go stock ls3 heads use dickey scoggins cnc ported the price is right.
06-17-2019, 07:42 AM | #4 |
old school muscle car guy
Drives: 2013 Camaro RS/SS 2SS Join Date: May 2019
So the L99 heads will allow a bigger cam then a LS3 heads do to the valve cuts in the piston correct? Not sure thats a good thing or not.
K&N CAI, SOLO Axle back, Jannetty tune
06-17-2019, 09:40 AM | #5 |
Drives: 2013 SS Join Date: May 2013
Depending on the budget ported stock heads 25-30whp gains, 10* valve angel and beefier cam 30-45whp gains etc...
Frankenstein released a budget friendly 11* LS3 head starting at $2200.00 assembled
06-17-2019, 10:05 AM | #6 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Is that for new heads or just a CNC and assembly job? I was just on the website and didn't see anything priced like that. Is it not on there yet?
More to come. |
06-17-2019, 10:46 PM | #7 | |
Drives: 2014 Chevy SS Join Date: Nov 2014
When they were on my car ('95 Impala SS), I dyno'ed at 473hp to the wheels....with a 229*/242* cam. KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
06-20-2019, 08:30 PM | #8 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
My shop told me Lingenfelter ported heads are good for maybe 15-20 hp on an NA ls3. Not worth it to me.
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
06-20-2019, 10:27 PM | #9 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Head is always worth it.
06-21-2019, 12:49 AM | #10 |
weSS1LEy
Haha tru dat! If a vendor could guarantee me a gain of up to 30 hp with aftermarket heads on my cammed setup then I would consider it for sure!
06-21-2019, 01:23 AM | #11 |
The average gain on ported stock heads is 15-20 depending on average aftermarket cams. Ive seen better gains with aftermarket castings like PRC because of the better port design and smaller chambers for more compression without milling.
06-21-2019, 03:50 AM | #12 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I did Trick Flow GenX 255's.
I did a lot of mods at the same time, so I don't know the rwhp gains from the TF heads alone.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
06-21-2019, 04:33 AM | #13 |
I gained 40rwhp going from BTR 3 cam and stock ported heads to TSP 4.2 and PRC 260s
06-22-2019, 02:17 AM | #14 |
weSS1LEy
What do you attribute that to? Say 10 from cam and 30 from heads?
