11-04-2016, 01:16 AM | #1 |
Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
How to get rid of the sound enhancer thing??
So tonight I installed the K&N Filter and Mishimoto Catch can as the 1st 2 additions...
When I was working under the hood, I noticed that long sound enhancer thing. I removed it in my last car (2016 GT) and it was a PITA, but there were lots of aftermarket options for capping the intake hose and firewall. The "kits" were like $10. Does anyone make something similar for our SS's?
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
11-04-2016, 05:58 AM | #2 |
Drives: 2SS, Hyper Blue, Sunroof, NPP, MRC Join Date: Jul 2016
You have my attention. I also be getting rid of the "sound tube". I'm not much for engine noise pumped in through the stereo or through a tube from the air box. These cars a complicated enough without adding this garbage to the mix.
11-04-2016, 06:20 AM | #3 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Mishimoto made one for my 2016 Subaru STI I really wish there was a clean option for our SS.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
11-04-2016, 06:27 AM | #4 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
A couple of the other CAI vendors have an option for deleting the sound tube. Check with them to see if they sell a kit separately. Also, have you checked with Mishimoto?
16 Red Hot 2SS A8: NPP, CAI Cold air, Ported TB, Fasterproms Ported intake, E85 flex, Formatto tuned. 11.80@118 with 1.92 60' (600-700 DA) on stock run flats.
11-04-2016, 06:30 AM | #5 |
Get a Rotofab.
"Democracy Dies in Darkness" |
11-04-2016, 08:21 AM | #6 |
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
11-04-2016, 08:45 AM | #7 |
I think you're referring to the Helmholtz resonators. They're in place to kill drone on your intake.
When I put my first CAI on my 2010 SS I started to notice drone at certain frequencies coming from the front.. kind of weirded me out at first until I realized what was causing it. A decent CAI is worth it anyway.. No downside. |
11-04-2016, 09:41 AM | #8 |
Drives: '19 Stingray '22 MB GLC 300 Join Date: Jan 2009
He's referring to the tube that channels intake noise to the firewall. The Rotofab cai has an option to keep it or not. If not, it includes a plate to seal off the hole in the firewall. That's what the other poster was referring to, a "kit" to seal the hole.
"Ever since we got the Camaro, everything seems better"
-My 6 year old daughter |
11-04-2016, 09:48 AM | #9 |
I am not an expert on CAIs, but the Roto-Fab CAI was engineered to have the sound tube delete as the stock box was engineered to have the tube in place.
You may want to check with a higher authority before just removing the tube and plugging the ends. There is no kit available that I am aware of.
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. Last edited by Hyper16; 11-04-2016 at 10:35 AM. |
11-04-2016, 10:17 AM | #10 |
Drives: 2016 mosaic black 2ss ash int A8 Join Date: Oct 2016
What does the sound tube have to engine management?
11-04-2016, 10:28 AM | #11 |
Drives: SS 6 speed of course Join Date: Jan 2016
nothing. My sound tube delete is a 5/8 heater plug sillyconed into the hole with a clamp.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
11-04-2016, 01:29 PM | #12 |
thanks guys. I would do a CAI, but this is my wife's new Daily and she won't let me. rofl
Also, we're in CA so smog is a concern :(
11-04-2016, 01:43 PM | #13 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
All you need is a simple rubber plug you could buy at the hardware store and MAYBE a hose clamp.
My Mishimoto CAI came with a much more sexy metal plug.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
11-04-2016, 02:39 PM | #14 |
Ok, so basically, I can surely remove the entire thing - and then the only parts I need to address are capping the hole left in the intake tube, and plugging the hole in the firewall?
