#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
BeckyD @ James Martin Chevy
Old 05-19-2021, 05:57 PM   #15
Waldo1
Drives: 2017 Chevrolet Camaro 50th
Originally Posted by cmitchell17 View Post
I don't think so I think they just skipped tightening a few of them, mine was built in March 2017. If you just get under there you can reach up and feel if the screws are loose or not. Be careful when you tighten them up (aluminum threads) or use a torque wrench to 18 ft lbs (#2 in picture), back 2 screws to 106 in lbs (#3 in picture) follow the sequence, some bolts you really won't be able to get a torque wrench on unless you have good tools but do the best you can:
Attachment 1026574
You don’t have a chart for the 2017 V6 do you. Mine is leaking and I suspect it is also coming from the oil pan.
Waldo1 is offline   Reply With Quote
Old 05-19-2021, 10:40 PM   #16
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
cmitchell17 is offline   Reply With Quote
Old 05-21-2021, 07:37 PM   #17
dr34m
Drives: Chevy Camaro
Ok thanks guys, I crawled back under there and sure enough almost all of them were loose. Makes me second guess my cam install and worried about my engine and what else the factory "forgot" to do haha
I got my torque wrench and torqued them to 25 Nm for the 13mm and 12 Nm for the 10mm according to the sequence in the service manual as best I could. A few of them I had to use a gear wrench to tighten and not the torque wrench since I couldnt get it in there.
im a dealer technician for mercedes, and i can personally tell you there's practically no quality control at all at factories. i doubt chevy is different.
2019 2SS - 544 wheel N/A thru the A10
dr34m is offline   Reply With Quote
Old 09-04-2021, 06:57 AM   #18
gen6_1ss
gen6_1ss's Avatar
Drives: 2023 Sharkskin Metallic 1LE
So apparently my car is having this same issue. Dealer cant get to it till next week. I checked the oil and it is still showing the oil level full, not low or anything. I should be ok driving it till I take it in right??
gen6_1ss is offline   Reply With Quote
Old 09-04-2021, 09:24 AM   #19
Puddin
Drives: 2016 Camaro 2SS
As long as you keep an eye on the oil level.
Puddin is offline   Reply With Quote
Old 09-04-2021, 01:15 PM   #20
SSUNDVL
Drives: 2016 Camaro SS
How badly is it leaking/ is it for sure oil? Are you sure it is oil pan? Are you modified/have you checked to see if it could be front/rear main?
SSUNDVL is offline   Reply With Quote
Old 09-05-2021, 06:32 AM   #21
gen6_1ss
gen6_1ss's Avatar
It's not leaking bad at all, only see a few drops on the ground every morning when I leave for work. The car runs fine and have no other issues. I took it to the dealer last week and they checked the oil filter and drain plug, both were tight. But due to them being so busy, i cant take it in till next week so they can get it on a lift and look into it deeper. And no I am not modded in any way, all completely stock.
Old 09-05-2021, 12:40 PM   #22
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Check your oil cooler bolts...those are notorious for being loose from the factory. Or they vibrate loose...either way mine came loose around 8k miles.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is online now   Reply With Quote
Old 09-06-2021, 07:06 AM   #23
Brudda*Termite
Brudda*Termite's Avatar
Drives: 2017 Camaro 2SS
I addressed this issue a year or so ago and found that the front four bolts were the problem, they were loose enough to tell by hand. Tightened them up, seeping issue went away...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
Old 09-15-2021, 05:28 PM   #24
gen6_1ss
gen6_1ss's Avatar
So update on my leak problem. I finally was able to take it to the dealer, it was in fact the oil pan that was leaking. They replaced the pan, gaskets, and did a full oil change. Service advisor said he has seen this issue before. I only have 24800 miles on the car, so now to get back to " spirited" driving.
Old 09-15-2021, 06:37 PM   #25
cmitchell17
They probably love when this happens, they can charge flat rate labor for changing a perfectly good oil pan gasket (there is no "gasket" actually, it is RTV'd) when they could have just tightened it up. I am not saying I am right but I think there is a lot of corruption obviously costing GM a lot of money in warranty claims.
Old 02-09-2023, 08:53 PM   #26
NicoLT1
Drives: 2020 Camaro LT1
Old thread but wanted to say I just had the same leak issue on mine and it ended up being that the oil pan bolts were loose. Originally saw a few drops on the oil cooler coolant hose so I cleaned it up and a few days later I saw a tiny bit of oil on the oil pan bolts. They were less than hand tight. Wouldn't have thought to check those bolts if not for this thread, so thanks!
Pic is of fluorescent dye we put in the oil to trace the leak.
NicoLT1 is offline   Reply With Quote
Old 04-01-2023, 08:28 PM   #27
WTS
Drives: Several
Oil Pan leak too
After oil change, service rep said there night be a leak. Not a surprise considering this would be the 3rd one in 5 years and 22k miles on this 2018.
First was loose hose connections, 2nd was improper dealer installed oil filter.
I never noticed any spotting this time and I was looking for it in the driveway.
Dealer just confirmed I need a new oil pan.
Warranty item.
WTS is offline   Reply With Quote
Old 05-08-2023, 06:31 PM   #28
tmalaquin
Drives: Blue ss 1le 18
This is happening to me as well on my 18 1Le, I have 51000 mile son it... dealer is asking to keep the car 3 days... seems excessive ! Do we have to drop the subframe to do access the oil pan and replace the gasket ?
tmalaquin is offline   Reply With Quote
