#Camaro6
Go Back   CAMARO6 > Engine | Drivetrain | Powertrain Technical Discussions > V8 LT1 Engine, Exhaust, and Bolt-Ons
Old 03-20-2024, 11:50 PM   #57
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
Originally Posted by 6spdhyperblue View Post
I wonder if you can text Btr a video of it running and see what they say
Yeah I think that would be a good idea, its just hard to hear the certain noises over the microphone on a recording.
I listened to it again today and its a very distinctive, clanky/clingey sounding noise. And it still gets louder the closer you get to the lifter/valley area.
I now have my 7.925 pushrods, so I guess I will give them a try even though its only 0.025 in more length, I guess its good to have different lengths of pushrods around for other builds if I can't sell them.
While I have the valve covers off I should listen with the stethoscope again and might be able to probe it on the actual rocker arm if I can do it without breaking something.
cmitchell17 is offline   Reply With Quote
Old 03-21-2024, 08:28 AM   #58
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Do you think you might be hearing the HPFP?
2016 NFG 1SS A8
Options-2SS Leather/NPP
Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP
Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA
KingLT1 is offline   Reply With Quote
Old 03-26-2024, 12:15 AM   #59
cmitchell17
I always have suspected that yes, but I can put the stethoscope on the fuel lines and identify the distinct injector and fuel pulse noises, I can also get closer to the HPFP but I don't hear anything get any louder. It is definitely loudest whenever I get near the valley cover area.
One thing I also want to do just to rule it out, is replace all the exhaust gaskets. I know usually everyone reuses the manifold gaskets I think I do remember seeing a little more soot around the exhaust port mounting surface, but I was in a hurry and didn't take a lot of time to look at it and I have taken it off and put it back on with the same stock MLS gasket a lot of times as well. I also ordered the ring for the collector seal and the metal flange gasket after the passenger side primary cat. I know exhaust leaks can sound a lot like ticks and lifter ticks so I need to just replace everything so I can rule that out.
With that said has anyone ever noticed their HPFP being louder after a cam swap with a bigger fuel lobe? I did double check the clearances to ensure the HPFP isn't bottoming out as well with the new cam. I am just running the stock fuel pump lobe lifter with no lash cap.
Old 03-30-2024, 06:26 PM   #60
cmitchell17
I replaced all the exhaust flange and manifold gaskets, and while I was at it I figured I would try putting in the 7.925 pushrods I ordered. Then I noticed the LS7 lifters had become solid then I noticed the 7.925s was holding the valves open. So I put the 7.900 I had been running back on and then the valve was still being held open. So couldn't figure out what was going on, especially with the very unpredictable way these lifters will pump up all the way solid even with a cold engine that hasn't been ran in 24 hours, and then no matter how long you wait they never bleed down, even 3 years because I had my original non-AFM lifter still pumped all fully all the way after 3 years of sitting there.
So I know for sure when I put in the 7.900s in a few weeks ago I had around 0.085 preload, so I figured even though I could clearly see the valve open, I would try the 7.925's anyway. So I did and I couldn't start it at all, you could hear the starter just spin with no load and it fire off a little but nothing, it wouldn't build any compression.
So tore it back apart again, and decided to go the opposite direction and put in some older 7.800 pushrods I had from my original cam install even though I was only getting about 0.040 of preload with them, they would allow the valves to close. The lifters also still felt fully pumped up and solid since you couldn't press them down no matter how hard you pushed on the top of the pushrod.
So it seems like the noise is the same. It may be HPFP related just because it gets really bad at around 1800-2000 rpms, then once you get past about 2200 rpms it almost disappears. It's real "clickity" sounding. These springs are supposed to be .710 max lift but I am wondering if they are binding somehow. I want to try the conicals but I just can't find any retainers since I can't find my original retainers and I think they got thrown away when my heads got CNC'ed.
Old 04-25-2024, 10:26 PM   #61
oldman
Drives: SS 6 speed of course
wow that sucks, I too went from TSP cam to cam motion mine is sub .600 lift. I had .660 lift txspeed valve springs but have since gone to much lighter springs for a LS that I have to shim in. Forget the specs now, I'll go look for them, I lowered the fuel cut from 7350 RPM to 6900 RPM. My cam looks good at 20K miles and 6 years. I hope I get 20K before I look at it again. I feel good that I went to a much lighter spring and lower fuel cut.
FWI GM has a NA cam for there L8P 218 /231 .549 lift on 121 LSA. which I would do if I have any issues with my current cam motion.
I thought this was interesting, they have a whipped out cam the blame the oil and sell the customer an even bigger cam.
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
oldman is offline   Reply With Quote
Old 04-26-2024, 06:48 AM   #62
6spdhyperblue
Drives: 6th gen
The shit coming from their videos make me cringe.
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold)
6spdhyperblue is offline   Reply With Quote
Old 04-26-2024, 07:33 AM   #63
arpad_m
arpad_m's Avatar
Drives: 2018 Camaro 2SS A8
+1, their derision almost oozes off the screen.
The boss (the guy who lost a lot of weight, his name is Fran, I think) has mellowed a bit, but based on a short sampling of their videos from many years ago and most recently, the rest of the crew has the same pompous attitude.
735 rwhp | 665 rwtq
Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune
1100 - 1/30/18 | 2000 - 1/31/18
3000 - 2/06/18 TPW 2/26/18
3400 - 2/19/18 | 3800 - 2/26/18
4300 - 2/27/18 | 4B00 - 3/01/18
4200 - 3/05/18 | 4800 - 3/14/18
5000 - 3/16/18 | 6000 - 3/19/18
arpad_m is offline   Reply With Quote
Old 04-26-2024, 08:55 AM   #64
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
I’m glad I’m not the only one who see’s this. If I keep my Camaro past the warranty period I am considering modding it. Even though these guys come highly recommended I wouldn’t take my car to them based on how they come off in their videos.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is offline   Reply With Quote
Old 04-26-2024, 07:02 PM   #65
oldman
Your lips to god's ears...
Old 04-27-2024, 07:40 PM   #66
cmitchell17
And to think how much people pay people like this and think they are getting something "good" and "quality" and "engineered" and "tested". They spend 99% of their time on instagram and social media.
Old 04-27-2024, 07:44 PM   #67
cmitchell17
I'm surprised the L8P dosen't make more power than it does. From what I thought it had the LT2 cam which is just the LT1 cam with a little more lift and duration if I can remember correctly. I didn't know it had a 218/231, now I would have thought it would have made even more power with that cam.
It's also funny how they gave it its own RPO code L8P, these RPOs are trademarked, maybe not all of them, but you would think if they went to the trouble of giving it its own RPO maybe they intended to do more with it in production environment, but I doubt so because of the 218/231 cam would never pass emissions.
Also did you notice anything quieter when you moved to softer springs?
Old 04-27-2024, 10:16 PM   #68
oldman
My valvetrain maybe a little more quiet, now that you mention it.
I did respec all the pushrods now that everything is broken in and I think I ended up with all the exact same length
I'm thinking I'm going to TSP adjustable rocker arms after this...
The LT1 hotcam is more radical and only makes a tad more HP. The L8P i s running a truck intake and a truck exhaust manifolds, I would think Camaro OEM headers and a LT2 intake / LT5 TB would bring 20 HP to the party, maybe a tad more, compare this to the crate motor big cam LS7 at 570 HP at some ungodly price. $16000 and even though I like the engine, I bet the L8P would last 3x as long...
