Old 01-23-2020, 07:02 AM   #1
deano1989
deano1989's Avatar
Drives: 2010 Camaro SS/RS
Heat Shields
Hey all,
I've started to notice a rattling noise coming from the heat shields on my Camaro. They are bolted on tightly still, it's the end part that isn't bolted on that is loose. I first started noticing it around December when it started to get cold outside. Has anyone had this problem before and found a solution?
deano1989 is offline   Reply With Quote
Old 01-23-2020, 07:40 AM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Nope. But on other cars I've just bent them so they aren't so close and can't touch whatever they are hitting.
Greenhornet2 is offline   Reply With Quote
Old 01-23-2020, 08:29 AM   #3
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
Tear it off. Fixed.
canadian ss is offline   Reply With Quote
Old 01-23-2020, 09:53 AM   #4
Vegas Bound
Drives: 2013 Sparkly Red One
I removed mine with the trans swap.
Vegas Bound is offline   Reply With Quote
Old 01-23-2020, 10:22 AM   #5
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
I had a similar issue near the driveshaft. I put some washers with some rubber pieces (old bike tube) and it helped a lot with the rattling
GJDM
LsxDoctor is offline   Reply With Quote
Old 01-23-2020, 10:58 AM   #6
deano1989
deano1989's Avatar
Thanks for all the input. I'm going to try and bend them first and then go from there. Anyone that's taken them off...have you noticed the floorboards or anything else getting hotter from taking them off?
Old 01-23-2020, 11:13 AM   #7
Vegas Bound
I live in Las Vegas and previously Dallas. I haven't noticed any difference.
Old 01-23-2020, 02:31 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
I would first try some sort of insulator like a piece of rubber or something else with good heat resistance that you can wedge between the shield and body. Otherwise you can try and bend it a bit like mentioned above.
Old 01-24-2020, 06:22 AM   #9
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
What kind of mods do you have? Perhaps something is hitting the heat shield that wasn't there from the factory? If so you may need to dimple or tie off something to fix the issue.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 02-04-2020, 06:41 AM   #10
deano1989
deano1989's Avatar
I have long tube headers with muffler delete axle back exhausts. It didn't look like anything was touching the shields and nothing felt loose, either. I went ahead and took the heat shields on both sides of the car off and I'm still hearing the noise, so it's not the shields causing it like I thought. At this point I'm not sure what it could be...any suggestions?
Old 02-06-2020, 04:06 AM   #11
SILVERHAWK
SILVERHAWK's Avatar
Drives: 2011 2SS/RS, '22 Silverado Z71
It sounds like you are having the same issue I am.... I have a thread on it in the suspension section because a mechanic friend said it may be the sway bar links..... but the jury is still out on whether or not that's the cause. I get a pretty good discount at a local part store so they should cost me around $70 for the set. Since my friend wasn't really convinced that would do it he told me to hold off for now. who knows.
SILVERHAWK is offline   Reply With Quote
Old 02-06-2020, 01:54 PM   #12
deano1989
deano1989's Avatar
I didn't think about checking the sway bars. I hear the rattling noise when I accelerate and stay around 1500 RPMs or when I let off the gas. The handling on the car seems fine and it doesn't seem to get worse when I turn the steering wheel. I would think if it was the stabilizer bar link or the bushings I would notice a difference when I turn the wheel. If I stay parked and hit the gas up to around 1500 RPMs I hear it too.
Old 02-11-2020, 09:29 AM   #13
SILVERHAWK
SILVERHAWK's Avatar
Our issues sound really similar I also get the noise at a certain rpm range and true I would also think that there would be some tell tale handling symptoms..... but so far other than the noise everything appears to be normal.....handles great and the ride is pretty smooth... no weird tire wear either.
I haven't tried the sitting still rev part though...…
Old 02-11-2020, 01:55 PM   #14
canadian ss
Psycho on day pass
Put a dab of grease on the underside (ribbed) part of the AC belt. Start it up and have try to reproduce the sound.
IF its still there, do the same on to the drive belt and start it up and reproduce the sound.
If it disappears, change the effected belt.
If there is still a noise, I would think its drive train possibly or torque converter?
