03-03-2016, 05:37 PM | #1 |
Re-tune needed for strong MAF sensor?
I recently had the AGP turbo kit installed and my car tuned. It seems to run good (love the turbos!!) but it has slight idle issues. I read the thread on the strong MAF and checked, unfortunately it has the weak sensor. Has anyone with the AGP kit changed out their MAF sensor without a retune?
03-03-2016, 07:16 PM | #2 |
Too much is never enough!
Do you have a MAF tune, or SD?
03-03-2016, 07:54 PM | #3 |
I'm not really sure but I think an MAF tune....
03-03-2016, 08:20 PM | #4 |
'It's an experiment'
Unreal may be able to help here. He is the guy to ask about AGP turbos...
-Don
747 RWHP 794 RWTQ
03-04-2016, 05:32 AM | #5 |
Best I can tell you to do is change the MAF, and watch your AFR. See how the car feels. That being said, they say that it is only a factor when you modify the airflow to the car, stock, a weak MAF will present no problems. You have obviously modified your airflow. I'm courious to know the answer to this myself.
03-04-2016, 11:23 AM | #6 | |
03-04-2016, 11:31 AM | #7 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
Not worth the risk to that nice setup to try and gain a few hp or response, if applicable. I would recommend spending $150 to $180 to get an AFR O2 sensor and gauge as cheap insurance and it is something you can continue to use, so it is not a waste.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
03-04-2016, 11:32 AM | #8 |
As soon as you tune a car, the weak/strong maf thing is not even an issue.
Check for boost leaks, vacuum leaks. Those are going to be the most common idle issues. If not could be in the tune. Who tuned it? They should be able to fix and determine why there is any idle issues.
Nick
Corvette Z06 -1200ish rwhp |
03-04-2016, 12:54 PM | #9 | |
I became concerned about the MAF the more I read about it on this site and confirmed that I have a weak MAF. I thought it became more of an issue when FI was added? I will probably just bring it back to the shop and talk to them about the MAF and see if they can tune out the bit of surging that I am getting... |
03-04-2016, 01:03 PM | #10 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
I would never have a FI motor without a afr gauge
Should be the first thing you do
03-04-2016, 01:28 PM | #11 |
Thanks guys! I'm learning as I go here... I'll start looking at AFR gauges...
03-04-2016, 03:37 PM | #12 |
Agreed. Don't worry about weak/strong mafs at all. It isn't even remotely an issue.
Nick
03-05-2016, 08:28 AM | #13 |
I've been reading some other threads and it looks like at a minimum I need an AFR and boost gauge. Are these mainly used to help with tuning or are there things inherent with a FI motor that may change and damage the motor without monitoring? Sorry for the basic question but this is my first FI car and I'm trying to explain to my wife why I need to spend more $$ on my car.......
03-05-2016, 09:03 AM | #14 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Do you have a wideband sensor in your exhaust? It may not be as simple as just getting an AFR Gauge. It needs a wideband to read from. A boost gauge can be plumbed in fairly easily. Or, you could get a ZR1 3 bar map sensor ($40) and modify 2 parameters in your tune (your tuner should do this for free for you...it's literally typing numbers in 2 boxes and that's it) and then you can read boost either with a gauge or electronically.
Here's an option for you that I used that's pretty slick: - Get a PLX gen 4 wideband ($150 + installation) - Get a ZR1 map sensor ($40) - Get a PLX kiwi 2 device ($85) - Get the PLX kiwi iMFR adapter ($50) - Download the DashCommand app on your phone or iPad or whatever ($10 I think) With all that, you can monitor and even datalog boost and afr right on your phone. It's really slick and works great. You can log a ton more data from the ECU as well with this set up. But I use it for ongoing boost and afr. I'm willing to help you with this if you want... |
