Old 01-25-2015, 08:08 PM   #1
arkentect
arkentect's Avatar
Drives: 2010 Camaro SGM 1LT M6
V6 noise on hard acceleration
So I just recently got this car 3 weeks ago and I love it. I have noticed tho that under hard acceleration from first through second and a little quieter into third the car has a rattle sound coming from near the motor. It almost sounds like the timing is too advanced. Has anyone else experienced this?
During normal driving you can't hear any rattle or knock, she purrs real nice.
arkentect is offline   Reply With Quote
Old 01-25-2015, 09:43 PM   #2
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
im guessing you have a cold air intake. Ever since i put mine on it does that
Tmick5jr is offline   Reply With Quote
Old 01-26-2015, 08:02 AM   #3
arkentect
arkentect's Avatar
nah its the stock intake air box. Although whoever owned the car before me did a number on it and some of the brackets are broken:/
Old 01-26-2015, 12:15 PM   #4
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
If your original owner hurriedly replaced some stock parts, it could well be the source of the rattle.
But be aware the fuel injection on these direct injection cars is under much higher pressure that before, and will cause a sound similar to a rattle under hard acceleration.
Old 01-26-2015, 02:52 PM   #5
arkentect
arkentect's Avatar
so it could just be a noise resulting from the direct injection?
Old 01-27-2015, 02:36 PM   #6
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
I work in Rochester (Henrietta) if you want to compare to what mine sounds like, but then again I have an intake and exhaust that would make it sound different anyway. If someone put stock parts back on in a rush and you are missing something let me know, I have stock parts laying around the garage - you could have whatever you are missing.
Also, you might want to check out UpstateC5 in the regional forums;
http://www.camaro5.com/forums/showthread.php?t=94769
Good club, good people, no dues or B.S., you do what you want. Lots of fun stuff though, my favorite are the events that include laps at Watkins Glen.
Either way, nice to see another one in Rochester.
Flashpoint135 is offline   Reply With Quote
Old 02-23-2015, 10:02 PM   #7
msmith0409
Drives: 2012 Camaro 1LS
My dealer snapped the oil filter gasket, when performing maintainance on my '12 1LS. Which caused loss of oil onto my timing belt, which in turn caused the tensioner to allow the belt to slip out of timing, and sounded like a rattling sound almost like a loose heatshield. It also gave off a burning oil smell from falling to the exhaust. After all was "fixed, and ok" came home today, 2 days later, and there is something leaking onto the ground under my front end.Anyway, i would make sure that oil filter isnt leaking.
msmith0409 is offline   Reply With Quote
Old 02-23-2015, 10:58 PM   #8
Red Jewel RS
Red Jewel RS's Avatar
Drives: 2010 Camaro 2SS
Engines will move on it's motor mounts under hard acceleration perhaps a metal piece is vibrating against something else.
Red Jewel RS is offline   Reply With Quote
Old 02-24-2015, 06:52 AM   #9
arkentect
arkentect's Avatar
Thanks for the replies guys... its almost Rpm variable. Maybe it is just the direct injection. Flashpoint I would be in for listening to yours for a comparison. Good to see another ROC native
Old 02-28-2015, 10:17 PM   #10
arkentect
arkentect's Avatar
So update... I was coming home from dinner with the girl tonight and decided to step on the throttle pretty good. First time I've brought the car close to redline since I've owned it. I merged onto the highway and stepped on it. After I left off and cam to a stop at the next light everything was fine, but when I stepped on the gas the ticking was much more noticeable, def louder. I drove around slow for a little and quieted down but now I can here it in neutral at 1300-1500 rpm.
Any ideas?
Edit: drive-ability doesn't seem affected. No rough idle either.
Old 02-28-2015, 10:59 PM   #11
arkentect
arkentect's Avatar
By the way the ticking can be heard inside the car with the doors closed and windows up... Kinda hoping this is the normal v6 DI ticking but idk. Hope I didn't break anything.
Old 03-01-2015, 12:20 AM   #12
stlrammer
stlrammer's Avatar
Drives: 2017 1SS Blue
Nice ride. Love the color. :-)
stlrammer is offline   Reply With Quote
Old 03-01-2015, 09:43 AM   #13
Ventmaster
Ventmaster's Avatar
I'm sticking with that DI ticking theory too.
Sometimes if an injector get's a bit dirty it can be louder. Try running some fuel injector cleaner thru the next couple of tanks of gas.
Old 03-01-2015, 10:27 AM   #14
Tmick5jr
Todd
Tmick5jr's Avatar
Drives: 2012 Camaro
my injectors make a clicking noise. Not that loud tho
