03-28-2019, 07:40 PM | #1 |
Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Wheel Backspace Recommendations
Friends; I am currently running OEM 21" wheels on my 2014 Camaro. As we all know the 21" tires are pricey to say the least. I have also found the ride to be a little less quality than the 20". Besides unable to rotate these buggers I have decided I am going to build me a set of 20" wheels.
What I really would like is to have a set of the 1LE wheels like the picture I will add. And... I really want to have a "SQUARE SETUP" with all four wheels having the same backspace. Wheels that I can mount 245/40/20 tires. What wheel specs would you folks that are much more well versed with this than I use? Wheels 20" Width ? Backspace ? Tires 245/40/20 My thanks, Larry
03-30-2019, 07:19 AM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
actually...….go with a 20 x 9....with a 40mm offset (stock configuration for SS's) and run the 275/40's puts a little more meat on the ground and fits like a champ. ran this SQUARED SET-UP for a long time.
03-30-2019, 08:31 PM | #3 |
Thank you very much for the response and most valued advise! I will now start looking for a set of 20" OEM black wheels. Larry
04-04-2019, 06:37 PM | #4 |
Drives: Camaro Z28 Join Date: Jan 2017
If you want to run a 245 width tire, stick to a 20x9" with something between a +20mm offset and a +35mm. Anything greater than that will be pretty tucked in.
If you want to run a 275 width tire, you really should run a wider wheel. 275 on a 9" wide is a waste as the outer edges won't even be touching the pavement. It is a much better fit for a 9.5" or even 10" wide wheel, both of which can fit the front or rear and be rotated no problem. - Cory
Cory - Fitment Specialist | Phone: 925.245.0773 | experts@apexraceparts.com
Website | Instagram | Facebook | Blog |
04-04-2019, 08:23 PM | #5 | |
Larry
