Old 01-06-2015, 11:45 AM   #1
Powellbr
Drives: '99 Mitsubishi Mirage de coupe
Best kind of automatic transmission for high horsepower (1800+HP)
Hey guys, as the name says I was wondering what the best kind of automatic transmission for ridiculously high horsepower numbers, like around 1800-2000+ horse. I'm going to be a building my Camaro that's gonna have that much power and the transmission is screwing me over because I can't find one. Thnx in advance for the information and plz be civil in your posts.
Powellbr is offline   Reply With Quote
Old 01-06-2015, 11:46 AM   #2
Powellbr
Guess I should also mention, I'm specifically looking for a 6-speed auto if possible but will do with 5 or more gears.
Old 01-06-2015, 01:32 PM   #3
Bo White
Bo White's Avatar
TH400
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 01-06-2015, 02:59 PM   #4
Powellbr
Could be my inexperience & lack of fully understanding of how autos work but is there a six speed variant of the th400 other than its grandkid the 6l80e which I was was already looking at but the highest rated one I found was 1,200 horse from PATC. Will google for information tho.
Old 01-06-2015, 03:47 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
You can make a TH400 a six speed by adding a gear vendors overdrive.
https://www.gearvendors.com/hrgm3s.html
http://www.jakesperformance.com/TH400.html
They offer transmissions for 1500+hp and it mentions 2000hp+ combos as well.
Out of curiosity, what are you doing with the car you want 1800hp+ and a six speed auto, besides going REALLY fast?
Old 01-06-2015, 03:53 PM   #6
Powellbr
Its gonna be a combo DD & drag car
Old 01-06-2015, 05:13 PM   #7
jrpxxii
jrpxxii's Avatar
TH400 is basically your only choice for that power.
Old 01-06-2015, 10:42 PM   #8
LS7 427
10.11 @ 136.32
LS7 427's Avatar
Drives: Black & Yellow 2SS/RS LPE LS7 427
Yup, that or a glide. Your at a minimum 1000hp off of what any 6 speed can handle, don't care who builds it.
Bryan
My Build Journal
Built, Tuned and Maintained By........
LS7 427 is offline   Reply With Quote
Old 01-07-2015, 12:46 AM   #9
Bo White
Bo White's Avatar
Yeah TH400 with about $5k or more in just parts and if you have to have a 6 speed throw a GV on the rear like Blake said.
Totalled:
Old 01-07-2015, 08:48 AM   #10
Powellbr
Well if it makes a difference, I'll be adding a trans cooler from Mishimoto to the setup, will that help a six speed or will it make no diff?
Old 01-07-2015, 09:27 AM   #11
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
You're looking to make 2000hp and talking about running a cheap a$$ trans cooler.
Trans cooler don't necessarily increase holding power. It's the decrease in trans temps that help it live and live longer.
ttshovel is offline   Reply With Quote
Old 01-07-2015, 09:50 AM   #12
H-E
Drives: 2010 zr1 Camaro 2011 vert
What are you doing for rear? That's alot of power.
H-E is offline   Reply With Quote
Old 01-07-2015, 09:53 AM   #13
Rat
Rat's Avatar
Drives: ZL1/TBSS/COPO
If your talking 1800rwhp you better look at a Glide. Power Glide or a Turbo Glide.
.....2012/14 COPO #33....427, 1.31 60' ....9.39@143......
Rat is offline   Reply With Quote
Old 01-07-2015, 11:54 AM   #14
Powellbr
I'm talking 1800+ @ the crank, altho some demented part of me wishes it was @ the wheels, tho it could be close because i'll be replacing the OEM motor mounts & bushings with ones from BMR Racing, altho with the motor mounts wont be using the poly will be using the pucks & adding sub-frame connectors from Granetelli Motorsports. Here are links to both:
Motor mounts: http://www.bmrsuspension.com/?page=p...284&superpro=0
Motor mount pucks: http://www.bmrsuspension.com/?page=p...293&superpro=0
Bushings: http://www.bmrsuspension.com/?page=p...464&superpro=0
Sub-frame connectors: http://granatellimotorsports.com/pro...e-2384-28.html
