10-20-2010, 10:25 AM | #1 |
Drives: White M6 1LT RS Join Date: Mar 2010
No Heat from Vents?!?!
So I was driving to work today.. It was about 50 degrees outside. Cold air was coming out of the vents. Even with the temp knob turned to full HOT!!!
Anybody have this weird issue? Looks like its time for a trip to the dealer. I did a search came up with nothing.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
10-20-2010, 10:34 AM | #2 |
Go Harder Than Baltimore!
Drives: 2010 CGM Join Date: Jun 2010
Yes I would take it the dealer. It could be a little thing, or a big one. The dealer would be able to tell you, anyways its under warranty.
10-20-2010, 10:36 AM | #3 |
Raised by Wolves
Trip to the dealer while you have a warrentee. My Cobalt was messed up like that but beyond warrantee so I just lived with it. The Camaro heater rocks and no cold air flow on the feet for me.
My el Camino was warm feet on the driver seat and cold air on the passenger. |
10-20-2010, 10:54 AM | #4 | |
Drives: 2LT Black '10 Camaro, 2000 Durango Join Date: Aug 2010
hey at least it happened now in the fall instead of in january |
10-20-2010, 11:26 AM | #5 |
Drives: 2010 2SS Join Date: Apr 2010
Don't you just love computer control?? This could be a mechanical issue also, but take it to the dealer as suggested.
10-20-2010, 03:08 PM | #6 |
Drives: 1SSRS RY L99 Join Date: Aug 2009
There have been a couple of guys that have had broken blend doors in the heater box.
10-20-2010, 03:20 PM | #7 |
Drives: Me 2001 F150, The wife '11 2SS RS Join Date: Aug 2010
Check your coolant level first then go to dealer
Similar Threads | ||||
Hot Air from Vents | cwalms | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 8 | 11-11-2010 04:22 PM |
NSCRA: August 29th, 2010, THE HEAT IS ON! | torque solution | Dragstrip and Launch Techniques Discussion | 0 | 08-14-2010 09:58 AM |
Installing Cold Air Inductions: Use hair dryer for heat shrink? | Peyton | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 11 | 08-09-2010 07:10 AM |
Unrestricted Motorsports Newly Release of Cowl Hood with Heat Extractors | unrestrictedmotorsports | Exterior Parts & Accessories | 7 | 12-23-2009 11:41 PM |
Heat out of vents around town. | TooCool5 | 5th Gen Camaro SS LS LT General Discussions | 18 | 08-21-2009 03:30 PM |
