Old 08-27-2017, 11:35 AM   #1
EV1L SS
Drives: 2010 ss , cam, magnacharger , etc
Tvs2300 owners with larger under hood IC tank
Hey, does anyone have an SS with a Maggie and larger IC tank under the hood? Like a zl1 style tank, I'm not wild about putting another tank in the trunk . Any recommendations and pictures are appreciated ... Also is a larger zl1 heat exchanger plug and play for a tvs 2300 ?
EV1L SS is offline   Reply With Quote
Old 08-27-2017, 12:56 PM   #2
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Great question
I have talked to Canton about a few design possibilities. I'm also curious about who is doing this and what design and locationnthey are using.
UNRIVALED SS is offline   Reply With Quote
Old 08-27-2017, 02:26 PM   #3
EV1L SS
So far I found this one from moroso, what do you think and will it fit
https://www.summitracing.com/parts/m...MobileSwitchNo
Old 08-27-2017, 02:27 PM   #4
EV1L SS
Wonder if one made for an 03/04 cobra could me retro-fit
Old 08-27-2017, 05:34 PM   #5
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
http://www.camaro5.com/forums/showthread.php?t=491531
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 08-28-2017, 08:05 AM   #6
Stay Marine
Still love daily drivin'
Stay Marine's Avatar
Drives: Built '10 IBM 2SS; '15 Black Z/28
I want to say Rotofab makes a reservoir out of an old windshield wiper tank--its been about 5 years since I did it, but when I went to a CAI intake, the bigger reservoir fit right up against the CAI housing and the wheel hub (about 1 gallon capacity). From there, went with Melling pump (23gpm) and an AFCO twin fan, dual pass I/C. Made a huge difference.
Stay Marine is offline   Reply With Quote
