11-27-2018, 11:21 AM | #1 |
Drives: Camaro V6 2011 and 2014 V6 Join Date: May 2017
My cooling fan starts only in 227Fº
Hello friends. I have My camaro since 1.5 years. But always has hot engine because the cooling fans starts only in 227 Fº, never before, only start in 227 Fº and cut off in 219Fº
Is there any way to make it turn on earlier like 210 F or less? I dont have any coolant leaks or anything, just my cooling fan are lazy and turn on late. Thanks! |
11-27-2018, 11:22 AM | #2 |
Its there a 200Fº fan switch like this eBay item for Camaro 92?
11-27-2018, 02:27 PM | #3 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
the only way to adjust when your fans come on is through tuning.coolant temp sensor does not control fans. Its sends the coolant temp to ECM. The ECM decides when they come on
Bone Stock |
11-27-2018, 03:21 PM | #4 |
GPI Sales Consultant
These guys are correct, you can only change the on/off points with a change to the tune. However, you can also install your own fan switch. PCM of NC makes a nice switch and harness - http://www.pcmofnc.com/product/2010-...tch-harness-3/
The other thing you need to understand is that the stock thermostat is a 187*F unit. That means it STARTS to open at 187*F and will typically settle (with good airflow through the radiator) about 10-15*F above that point. So, with a stock thermostat you'll only get it cooled down into the 200*F range. You can buy and install a low temperature thermostat. I prefer the 169*F Mishimoto unit. Here is a good write up I did on that unit and why you might want that instead of the typical 160*F thermostat most opt with. https://www.camaro5.com/forums/showthread.php?t=505083
Got a question about a GPI product? Feel free to shoot me a message! |
11-27-2018, 03:39 PM | #5 |
Thanks guys. I read a lot with HP TUNERS can modify the PCM to the fan speed and temperature to on and off, If this correct?
Like I said before, my fans only turns when temperature reach 227Fº and cut off in 219 Fº. I want to modify that, if its possible, my fans turn on in 212Fº, it will be great |
11-27-2018, 03:52 PM | #6 | |
So, for your application you'd be fine.
11-29-2018, 01:18 PM | #7 |
Drives: 2012 Camaro RS 2LT 6spd man Join Date: Aug 2013
Mine did this as well, but learned that my system was low on coolant or air pocket, it's supposed to kick on at 221 and lower the temps to around 205, at least mine does since I had it. Once I filled the system to spec, it was working normally again.
11-29-2018, 01:26 PM | #8 |
Is there another scanner for tuner the fan speeds or its only possible with HP Tuners?
12-03-2018, 07:33 PM | #9 |
In my country, I only found a shop that has the HP Tuners but they want to charge me 180 U$ only for change the temperature fan tune.
12-04-2018, 07:08 AM | #10 |
Unfortunately that's not shocking. The credits alone (for them to access the computer) are $100 their cost. Put on some markup, some time, and some tax, and there ya go. I would look into a full remote tune. RDP, a vendor on this forum offers them. So does GPI, a vendor I really like to work with. Not sure what your other options are for tuning - I'm sure there are other ways but none that I've used.
12-04-2018, 11:16 AM | #11 |
I was wanting to buy hp Tuners on ebay today, so do I need credits just to set up my vehicle's fan?
12-04-2018, 11:29 AM | #12 |
I believe you'll need two credits to make any changes to your car. You'll want to validate that before purchasing with the purchaser.
12-05-2018, 05:24 AM | #13 | |
But my Camaro now has problem again with overheating after more than a year! I hate the car.. I want to sell as soon as possible and buy a 2014 BMW 320i. Yesterday in traffic, the coolant temperature start reaching to 242 Fº The car has problem again with temperature This its my post of last year https://www.camaro5.com/forums/showthread.php?t=496308 Its fixed about 15 months but yesterday the problems start again.. |
12-05-2018, 05:39 AM | #14 | |
This its my video of last year when the car has overheating problems..
Solved for more than 1 year, now yesterday the f....cking problem start again |
