08-02-2017, 01:43 PM | #1 |
Drives: 2019 ZL1-1LE A10 Join Date: Jan 2017
Headers?
Has anyone added headers? I'm curious what Brand, with or without cats and factory muffler w/NPP or aftermarket mufflers. Having hard time finding ZL1 specific headers. Most just say 2016-newer Camaro SS.
19 ZL1-1LE A10
08-02-2017, 06:48 PM | #2 |
Drives: 2011 Camaro SS Join Date: Jul 2017
I believe they are the same.
08-02-2017, 07:12 PM | #3 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
There are no specific ZL1 headers to my knowledge. All the headers that work with the SS will work on the ZL1.
08-07-2017, 01:27 PM | #4 |
Drives: 2002 Camaro SS Join Date: May 2016
2" Stainless Works, no cats, with full Stainless works catback here:
https://www.facebook.com/whiteheadmo...8735096170430/ |
08-07-2017, 03:08 PM | #5 |
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
TSP has them. And as mentioned, the SS headers will also work on the ZL1. I plan to get a set of TSP 2 inch catless at the end of this week. I already have a catback that deletes the exhaust valves and I'm pretty happy with it! The headers should make it even nicer!!
08-07-2017, 03:10 PM | #6 | |
08-08-2017, 11:22 AM | #7 |
I did not, but from what I understand it was a little bit more difficult than a 5th gen.
2018 ZL1 A10 | 2017 Ford Raptor | 2002 SS #2847 - Brembo - Koni - Recaro | 2000 SS #3825 - Huron Speed Turbo Build | 1986 Regal T-Type
08-08-2017, 11:26 AM | #8 |
Drives: Fast Join Date: Mar 2015
LT4 cars are tighter than the previous G5 Camaro and C6 Vettes, but still doable.
Top quality headers are American Racing Headers (ARH) and Kooks, with the rest falling slightly behind. |
08-08-2017, 12:06 PM | #9 |
Drives: 2017 ZL1 A10 Join Date: Aug 2016
ARH 2" primaries will drop in from top on passenger side once you remove the heat shield from starter to drop in and then put it back on. But make sure to put heat shield back on once header loosely fastened to head, if you torque it down you will not be able to get to the 10mm (head) bolts to put the heat shield back on.
For drivers side have to go up through bottom. Remove steering link and remove the bracket holding plug that front O2 sensor plugs into. My car is approximately 18" off ground and it went in relatively easily. It does help to remove valve cover on passenger side when sliding header in from the top, but may not be necessary with 1-7/8 primaries. |
08-08-2017, 12:40 PM | #10 |
Drives: 2017 ZL1 Join Date: May 2010
If you're not planning on future boost increases or cam what would be better; 1-7/8" or 2"?
08-08-2017, 01:43 PM | #11 | |
08-08-2017, 01:56 PM | #12 | |
Now, this is for the ARH 2" primary headers, something like the Kooks or Stainless Works could be a little different depending on how the tubing is bent, I'm just not sure. I really did not think it was difficult, but everyone has different mechanical experiences. |
08-08-2017, 10:38 PM | #13 |
Drives: 2017 ZL1 Join Date: Mar 2017
I ordered Kooks 2" headers with green cats in April. Still haven't seen them or heard when they will ship. Looks like I'll be missing my install date in September.
2017 Camaro ZL1, Nightfall Gray Metallic: M6, PDR, exposed CF, navigation, sunroof
Mods: Rotofab CAI, Tony Mamo TB, Kooks headers (green cats), 18% LPE lower pulley, E85/FlexFuel sensor. BC Forged RS41s (19x10, 19x12)/PS4S, R888R (305/325) Dyno: E40: 661whp/703wtq, 93: 633whp/674wtq |
08-09-2017, 04:07 PM | #14 |
Drives: Camaro Join Date: Apr 2009
Texas Speed has long tubes in stock. I'll try to track test and dyno test soon!
