03-25-2019, 10:01 AM | #1 |
Drives: 2016 camaro ss Join Date: Apr 2018
Need a new block 😩
Well I finally got all my parts for my build picked block up from machine shop. Started assembling it got all my rings gapped and bearings clearances checked and assembled it. Wellllllllll got it all together and went to spin it and it would spin about 180 degrees. At that point I started taking everything apart. I found that cylinder one had a dent and crack in it from a timing cover bolt that was too long for that spot torque to 18ftlbs. So my block is trashed 😩. Does anyone happen to have one they can sell? Not wanting to waste money on a factory new block.
03-25-2019, 10:28 AM | #2 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
can't you get it sleeved?
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels & brakes/GForce DS and axles/ZLE Cradle Bushings/FE4 ARB front & rear/SEMA Grill/Rotofab dry/95mm TB/Magnuson 2300/Full LT4 fuel system/JMS boost-a-pump/E85 Sensor/Ported CID heads from LME/Cammotion PD cam/Thompson Motorsports forged shortblock/catted Kooks 1 7/8 headers /JRE remote tuned |
03-25-2019, 10:34 AM | #3 |
No it damaged the aluminum that they’d need when they resleeve.
03-25-2019, 10:56 AM | #4 |
Drives: 2022 Lt1 A10 Join Date: Nov 2015
Man that really sucks for sure. Sorry to hear that.
2022 Lt1 6.2 A10, Maggie 2300, THPSI Port Inj/10 rib, Rotofab, E, Nickey, SCOL, Griptech, RC Bandits, Hoosiers/MT 9.80@142.96 1.44 60ft, 6.34@112 707/669 RWHP/TRQ. 16SS Maggie 2650 9.41@147 1.35 60ft, 5.99@119. 16 C7 A8 10.90@128 Bolt on stuff
03-25-2019, 11:07 AM | #5 |
Drives: 6th gen Join Date: Aug 2013
Prob better luck finding out out of a truck?
‘22 2SS 1LE M6 Summit White - RF, Flexfuel, LT2 intake, 95mm tb, ATI udp, VT ramair, full 28” dragpack - 11.68@122
‘16 1SS M6 LT2 intake + boltons on DR 11.0@126+ (Sold) |
03-25-2019, 11:32 AM | #6 | |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
03-25-2019, 11:43 AM | #7 |
I’m sure I grabbed wrong one by accident. I’m not totally sure though because by the time I realized it I had already removed everything and bolts were in a pile. Just horrible luck. I literally posted pics of the motor with the caption “this went suspiciously smooth” then 30 minutes later found that it had a problem lol. (I put lol but it’s more of a crying man laugh) I even called the machine shop and he said he had never seen that and that he would have thought the bolt would strip before that. When I told it was only torqued to 18ftlbs he was even more shocked.
03-27-2019, 07:12 AM | #8 |
Drives: Black Join Date: Jan 2017
03-28-2019, 11:52 PM | #9 |
Drives: Camaro Join Date: Apr 2009
Call tsp and get a Resleeve.
03-29-2019, 10:38 AM | #10 |
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
he is better off with a different block that way they don't have to tig the crack/hole shut. suspect issues later on if not repaired correctly.
besides a stock block is probably alot cheaper than sleeves & accompanying machine work i do see that whatwarranty is close to texas-speed; so your right that's always a option.. whatwarranty you can order a new cylinder block from jegs and swap your water/oil plugs on over. https://www.jegs.com/i/Chevrolet-Per...29617/10002/-1
