Old 11-14-2019, 11:55 AM   #1
dgoode2359
Drives: 2010 Black 2SS
NPP exhaust on 2010 2SS
Hey guys, I know the answer is out there somewhere but I can’t find a straight answer, so maybe someone here can help.
I wanna install the NPP exhaust on my 2SS, but I would have no way to control the valves. I plan on doing a cam and LTs so I would like to have the control over the valves. I’m really only interested in the look of the dual tips, so if anyone knows of a pretty decently quiet dual tip set of mufflers, I’d be interested in that too, I can always run my own electric cutouts. I’ve heard of the Mild2Wild, I just don’t know if that will work on my car or if I’d need to run a vacuum source as well, instead of it just being a bolt on. No big issue, just can’t get a straight answer from anyone. Or if there is another way of controlling it? The Mild2Wild seems like the best and easiest option, like I said, just don’t know if it will work on my car
dgoode2359 is offline   Reply With Quote
Old 11-14-2019, 12:41 PM   #2
Yellow 1
Grumpy Grey-haired Guy
Yellow 1's Avatar
Drives: Camaro, Corvette & Merc C300(daily)
Get a set of Noweeds; they're as much fun as beer or shooting. Plus, you can take 'em off and fit 'em to the next car you get. Three settings, all controlled from the seat. Almost as much fun as the blower.
Yellow 1 is offline   Reply With Quote
Old 11-15-2019, 04:39 AM   #3
dgoode2359
Definitely was looking into a set of noweeds cutouts, but I still want the dual tips, so it’d be nice to be able to have the valves work and save $900. I guess I could just run them with the valves not hooked up and closed lol.
Old 11-15-2019, 06:04 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So you need to find the exhaust obliviously, then you’ll need a 1LE diffuser, and now go to the DIY section and there’s a thread there on how to make you own system out of after market parts and a mild to wild switch. Biggest expense will be the vacuum reservoir and the mild to mild switch.
https://www.camaro5.com/forums/showt...=314023&page=3
Orange Krush II
Old 11-15-2019, 09:27 AM   #5
dgoode2359
Yep, tracking on the 1LE diffuser and exhaust. I checked out the link, and from what I gather it wouldn’t give me total control over the valves, I would only have control on whether the valves open with engine load or they stay open all the time. Was more looking for an either always open or always closed method.
Old 11-15-2019, 10:42 AM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Their is a thread for a homemade setup but couldn’t find it
Orange Krush II
Old 11-16-2019, 05:31 AM   #7
dgoode2359
I found exactly what I’m looking for, but it’s for cars that came with the NPP.. So far no solutions for me besides hooking it up to vacuum and basically running it like factory. I could always have a exhaust shop cut out the vacuum operated valve and weld in a electric cutout. That’s probably the simplest route for me.
Old 11-16-2019, 07:34 AM   #8
PhantomBlack
Drives: 2014 Camaro 2SS
This is the one I'm going to go with. Has everything you are looking for : http://bulletperf.com/chevrolet-cama...eries-w-cutout
PhantomBlack is offline   Reply With Quote
Old 11-16-2019, 07:04 PM   #9
Quicksilver2SS
Quicksilver2SS's Avatar
Drives: 2SS/RS LS3 NPP
I pulled the fuse on my NPP exhaust which opens the valve full time, just an idea but maybe just install the system with the valves jammed open and see if you like it. Its far from loud, but without cam/lt's.
If not, then go into the trouble and expense of making the system open/close...
Yes there are dual tip mufflers that will give you the look.
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
Quicksilver2SS is offline   Reply With Quote
Old 11-16-2019, 07:40 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
The valves default open so no need to jam them open.
Orange Krush II
Old 11-17-2019, 05:57 PM   #11
dgoode2359
Yes I’m aware there air dual tip mufflers lol.. was seeing if anyone had any recommendations for any mufflers that are more on the quiet side lol, which I know is hard to find, but you never know
Old 11-17-2019, 05:58 PM   #12
dgoode2359
I’ll check that out. Thanks
Old 11-17-2019, 07:49 PM   #13
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
You can wire them closed all the time if you just want it quite.
JD555 is offline   Reply With Quote
Old 11-18-2019, 05:03 AM   #14
dgoode2359
They’d need a constant vacuum source correct? Say if I ran a vacuum line to the intake manifold the vacuum would make the valves actuate based on the amount of vacuum its building depending on engine RPM. How could I wire them closed?
