11-16-2011, 03:06 PM | #1 |
Retired
Drives: 2010 Camaro RS V6 #1301 DOB 3/23/09 Join Date: Aug 2009
RESOLVING VIBRATION ISSUE
My car has had a vibration under load that becomes apparent at about 60 mph and progressively worsens as speed increases. Took it to a dealer today and without doing a vibration test the tentatively concluded that the u-joint connecting the driveshafts is bad or misaligned. They chose to order a new driveshaft assembly rather than tearing it apart today and having to reassemble it if the joint is bad. The joint is not available as a seperate part so they have to replace the entire thing from trani to dif. if it is bad.
11-16-2011, 03:59 PM | #2 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
So are they acting like they're gonna warranty it!
11-16-2011, 04:30 PM | #3 |
I wonder what conditions can mess up the u-joint....
Formerly owner of:
2012 2SS/RS Build Thread - Totaled by red light runner 2010 LT/RS Build Thread - Traded in for 2012 2SS 2007 Acura TSX 1992 Oldsmobile Achieva V6 1992 Mercury Sable |
11-16-2011, 04:42 PM | #4 |
Red Brick of Vengeance!
Drives: 12 Second Brick Join Date: Jun 2009
Hope they get it straightened out for you!!!
Because... tick-tock... Black Friday.... LOL
11-17-2011, 07:41 AM | #5 |
Retired
11-17-2011, 07:42 AM | #6 |
Retired
11-17-2011, 07:43 AM | #7 |
Retired
11-17-2011, 07:45 AM | #8 |
12-06-2011, 01:07 PM | #9 |
Retired
Ok so GM decides they want a vibration location test done before they start pumping $ in it. Good thing. Problem was the left axle shaft. Should be good to go by weeks end. As for the shifting issue. I was told by 2 techs it has to be in the trani tune. I will just ditch that particular tune and load another and see what shakes out.
12-06-2011, 06:19 PM | #10 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
Glad to hear your've got that figured out!
2010 Camaro 1LT V6 (Sold. I will miss her!) |
12-06-2011, 06:25 PM | #11 |
12-07-2011, 12:24 PM | #12 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
Might try just reloading the trans tune?
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
12-23-2011, 04:05 PM | #13 |
Retired
Both rear axles replaced. Vibration issue gone!!!!!!!!!!!!! Tima get back in the hunt!
12-23-2011, 08:43 PM | #14 | |
How's the tranny been acting?
Similar Threads | ||||
BIG 2011 Camaro......Issue | DJDADAH | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 37 | 05-03-2011 03:13 PM |
Dealership Screw Up - Clearcoat Issue | FDNY-L107 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 04-26-2011 10:52 AM |
window indexing issue | TripleB | 5th Gen Camaro SS LS LT General Discussions | 9 | 03-20-2011 11:19 AM |
Sequential Tail Light Issue | 40again | Cosmetics and Lighting Modification Discussions | 5 | 03-17-2011 01:33 AM |
HVAC issue... Anyone had this problem? | nashstat | 5th Gen Camaro SS LS LT General Discussions | 8 | 01-27-2010 04:19 PM |
