Old 08-12-2017, 09:33 PM   #1
bsimms89
bsimms89's Avatar
Drives: 2012 SS/RS Vert & 2017COPO#23 SC350
10L80 swap
Anyone know when the 10L80 will be available to buy and how complicated it would be to swap into a 5th gen? Considering a project in the future to install an LSX454 in my 2012 along with the 10 speed to use as a street car an occasionally on a road course
2012 IOM Camaro Convertible 2SS/RS, A6/L99, ARH Longtube headers, high flow cats, x-pipe & mufflers
CAI Cold Air Intake, Kaltech Tuned
2017 COPO #23 Black w/ Supercharged LSX350
2014 Raptor 6.2L Tuxedo Black Metallic w/ 2.9L Whipple, 78Lb/hr fuel injectors, Ford Racing Dual 65mm cobrajet throttle body, kooks headers & exhaust.
1969 Camaro SS (original SS350), Black w/ white Rally Stripes, new ZZ502ci 502hp motor, muncie 4 speed, 4.11 rear
bsimms89 is offline   Reply With Quote
Old 08-24-2017, 11:59 PM   #2
zfrederick
zfrederick's Avatar
Drives: Black 2010 2ss
So I'm not sure but the top bolt on the bell housing and block on LT blocks are off set so the will not directly mount to an LS. Now I'm not sure about the other bolts but I'm sure they are probably different too
the parts never end!!!!!
zfrederick is offline   Reply With Quote
Old 08-25-2017, 01:08 AM   #3
Bo White
Bo White's Avatar
If thats the only difference in mounting then thats nothing. If the other bolts line up you will be just fine.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 08-25-2017, 03:01 AM   #4
bayarea408
bayarea408's Avatar
Drives: T
sub'd
bayarea408 is offline   Reply With Quote
Old 08-25-2017, 01:50 PM   #5
CGbambam
Drives: 2011 Camaro 2SS
Don't think the mounting will be the problem, having an aftermarket way to control the computer will be the headache.
CGbambam is offline   Reply With Quote
Old 08-25-2017, 08:11 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
That was my question also, computer control. Aftermarket may come up with a solution if these 10 speed trans become the cats meow...
That would be a heck of an update to the 5th Gen!
-Don
747 RWHP 794 RWTQ
Old 08-26-2017, 11:24 AM   #7
Synner
Drives: cars
I don't think even a standalone module would fit the bill, it would take a module that talks to the ECU since they're so interrelated. I doubt GM would come up with it since there is no factory requirement to do so, even for older retrofits. Unfortunately I think most aftermarket companies would put all their focus on the 6th gen since that's where the money is now with the latest and greatest.
Old 08-26-2017, 08:17 PM   #8
DSX Tuning
Drives: 2019 Corvette ZR1
The CAN communication won't be compatible.
DSX Tuning is offline   Reply With Quote
Old 09-01-2017, 04:16 AM   #9
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
same here:
http://www.camaro5.com/forums/showthread.php?t=497581
The CAN bus piece will be the hill to conquer.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 02-10-2018, 04:34 PM   #10
bsimms89
bsimms89's Avatar
Well i guess I'll just go for the LSX454 first and see if one day someone develops a way to make them work together. Only other curiosity is if they have plans of coming out with an LTX kind of crate motors anytime soon. I'd also be interested if someone develops a way to control it to swap the 10 speed into my 2014 Raptor with the 6.2L that I'm about to install a whipple on.
Old 11-28-2018, 10:57 AM   #11
racesloth
Dan
Looks like a way to control the 10R80 independently is being worked on for fords. GM prob to follow.
US Shift:
https://www.usshift.com/silverbullet.shtml
Dan
2010 IOM SS
Old 01-20-2019, 09:13 PM   #12
John_C
LSx FTW!!!
John_C's Avatar
Drives: 2010 Camaro 2SS RS
Another here wishing I could get the fast shifting A10 swapped in my 5th Gen.
Surely someone is going to have A10 swaps available eventually for us, right?
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X
Circle D 3400 Triple Disc
Kooks Jet Hot Headers
Kooks Full 3in exhaust
Trick Flow GenX 255's
Polished PAC .660's & Ti-retainers
TSP VVT 3.2 cam kit w/DoD Delete
Smith Bro's Trunnion kit
AEM X-Series OBDII Widebands
FIC ID1300x Injectors
GM ZL1 High Output Fuel Pump
DSX Tuning Flex Sensor
DSX Auxiliary Fuel System
Tim King Stage 4 Max Effort CTSV 6L90
DSS 1 piece aluminum driveshaft
JRE 6L80E / 6L90E Dipstick
NGK Iridium IX spark plugs #7 heat range
Mighty Mouse Camaro 5 Wild w/-12an and Billet Black
HP Tuners VCM Suite
John_C is offline   Reply With Quote
Old 01-21-2019, 09:49 PM   #13
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
Definitely watching this thread
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 01-30-2019, 09:16 AM   #14
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Interested in this as well
gunchamp is offline   Reply With Quote
