04-19-2021, 09:42 PM | #1 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
I promised I wouldn't ask the question...
But, I'm trying something different and I'd like some simple opinions. I want a smallish cam with good torque and good driving manners and not having to go dual valve springs and have to replace in 20k. So I went a different direction that appeals to me. No need to get technical, just what do you think.
CAM Motion 220/226 .558/.536 +3 115 LSA.. should be stout just not overly. I'll be burying this over time as I'm in no hurry because the 3.91's really woke it up. With only 36k on the clock I see no need for lifters or oil pump. 5/16 ,080 hardened pushrods and timing cover gasket. Probably Joe Gibbs for break in oil. Only thing I'm on the fence about is an oil pump. Always used conventional motor oil an had no issues. If I do replace would it be correct to use the melling high volume pump? Thank you for your input. Bill
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
04-20-2021, 05:55 AM | #2 |
Drives: 2010 Turbo LS3 Join Date: Dec 2009
I would put the Melling pump in regardless. I had an LS3 fail at 70k because the stock oil pump relief stuck open.
2010 SS - Kind of an On3 kit, CTR 78/80, CompCam 239/251 620/632 122+4, E85, Z28 suspension and ZL1 diff with Outlaw axles. Gen6 ZL1/1LE brakes.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. ZL1 brakes. |
04-20-2021, 06:09 AM | #3 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Melling is relatively cheap insurance while you are that far in.
04-20-2021, 06:18 AM | #4 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Check out the Summit Ghost cam. 222/233 115+3, .600/.575 and you can pick up a package with beehive springs and seals for $500
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
04-20-2021, 06:26 AM | #5 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Since the car only has 36k miles on it , it will take you over 5 years before you put another 20k on. Why not go dual for safety reasons? And plenty of people don’t change them out every 20k. Just my opinion.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-20-2021, 09:52 AM | #6 |
I'm not against duals. I just think it overkill for my cam. And I do plan an many road trips now that im retired...so miles will go on quicker. But i will think about it an ask my builder.
04-20-2021, 09:53 AM | #7 |
Is it the melling high volume or high pressure pump?
04-20-2021, 09:54 AM | #8 |
Thought about this one in the past. But this time i want to try my hand at a custom cam.
04-20-2021, 03:54 PM | #9 |
Melling 10295 is the pump I have in my L99, and it is the one my shop uses to replace the "failing" LS3 pumps. Also if you do decide to go with the dual springs, you will have more "seat" pressure on the valves which in turn will make sure they always close and seal properly, the singles will do it, but the duals will do it better I would think, and they would last longer too because they wouldn't have to work as hard. Just my thoughts.
04-20-2021, 04:44 PM | #10 | |
melling is kinda confusing on what application is best used.
04-20-2021, 04:49 PM | #11 |
Drives: 13' 1LE Join Date: Apr 2012
If you wanna stay reliable and not swap out springs too often, good idea. Still , I would invest in a high quality springs/retainers $$$
You CANT cheap out on the Melling. Get the high pressure. Thats what have, its been great for 25k miles+ with 7100-7900 rpm for 3 years. My stock tensioner was broken at 25k miles ish on the car, pieces floating around waiting to cause a disaster. Just a little information for ya; I had 'regular' doubles springs with quality retainers and after one summer on a solid roller/.720 lift, the locks dug a little into the retainers and they were stuck so hard i had to cut some part of it to remove springs (heads on car, cyl 8). Yeah the parts were not up to the task, but all parts fail someday, keep that in mind. I would change the springs on your setup no later than 25k max.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-20-2021, 07:43 PM | #12 |
They put the high pressure spring in it, not sure what color it is, but the instructions should tell you. At idle I'm sitting at 35psi, and cruising at around 1800-2000 I'm sitting at 55psi, cold startups it sits at 68psi and as it warms up to temp it will drop down to around 55-60ish..
04-21-2021, 04:15 AM | #13 |
Drives: Ashen grey, 1SS, L99 Join Date: Aug 2016
Agreed, and do the oil pump. I remember a member that had Superman or something in his username and he had no miles on his LS3 and boom! Oil pump failure. His freaking catch can voided the warranty. Stupid GM smh. Do the oil pump!
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported LS3 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, 1 Walbro 450lph, 2 525lph return style fuel system, deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Lolly pop Lime brake calipers, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
04-21-2021, 08:31 AM | #14 |
Yes, do the pump! Good insurance for sure. And that was "IKILLEDSUPERMAN"...
